0 Replies Latest reply on Sep 17, 2009 8:37 AM by Carol L. Frampton
    [svn:fx-gumbo_beta2] 10342: Submitting for Gordon but I changed it slightly .
    Carol L. Frampton Level 2
      Revision: 10342
      Author:   cframpto@adobe.com
      Date:     2009-09-17 08:37:04 -0700 (Thu, 17 Sep 2009)
      Log Message:
      Submitting for Gordon but I changed it slightly.  Regression caused by my SDK-23002 fix.
      The damage handler may be called because _textFlow changed, but it could also be called because of a state transition which restores a saved textFlow, via add content/createTextFlowFromContent, or the user modified the textFlow directly.
      Don't assume the textFlow that is damaged is _textFlow.  Only check/update lastGeneration if the target is _textFlow.
      Also need to update lastGeneration whenever _textFlow is set to keep them in sync.
      QE notes: please add a mustella test for this
      Doc notes:
      Bugs: SDK-23120
      Reviewer: Gordon and Carol
      Tests run: checkintests, GraphicTags tests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23002
          http://bugs.adobe.com/jira/browse/SDK-23120
      Modified Paths:
          flex/sdk/branches/gumbo_beta2/frameworks/projects/spark/src/spark/components/RichText.as
