3 Replies Latest reply on Sep 20, 2009 2:58 AM by glaustin
    Splicing Scenes Together
    glaustin Level 2
      Hi Guys
      I have a project in two scenes. Is there a way of joining the scenes into one movie in the project so they play in one go or do I have to output as AVI and join them together in a new project. I'm trialing Pr and haven't got Encore yet, so I don't know if this is something I can fix there (apols if this is basic but I cannot find a thread).
        • 1. Re: Splicing Scenes Together
          tclark513 Level 3
          Nest both sequences into a new timeline.
          • 2. Re: Splicing Scenes Together
            Colin Brougham Level 6
            When you say "scenes" do you mean you have two video files or two sequences that you want to join? If you're talking about video, just create one sequence that matches the video format and and put the clips in back to back. Then, export as a new video file, again using an export setting that matches the original; Premiere/Media Encoder won't recompress the frames if you use the same codec (ie. DV source files > DV sequence > DV export).
            If you're talking about sequences, just make a new sequence that again matches the originals. Drag the original sequences from the Project panel into the new sequence; the sequences will be "nested" and will act as if they are single video clips. You can then export one video file from the final sequence.
            Also, Encore will allow you to put two AVI files in one timeline; when you begin building the DVD, the two AVIs will be encoded as one MPEG-2 stream.
            • 3. Re: Splicing Scenes Together
              glaustin Level 2
              Thanks guys,
              Yes it is two sequences that I need to make one sequence from, following Colin's advice.
