0 Replies Latest reply on Sep 17, 2009 11:18 AM by Paul Reilly
    [svn:fx-trunk] 10345: * Updated two way data binding to work more intuitively by having the
    Paul Reilly Level 1
      Revision: 10345
      Author:   preilly@adobe.com
      Date:     2009-09-17 11:18:01 -0700 (Thu, 17 Sep 2009)
      Log Message:
      • Updated two way data binding to work more intuitively by having the
        primary execute successfully first.
      QE notes: A follow on checkin will address the couple of new mxunit
                databinding failures.
      Doc notes: We should document that with two way data bindings, the
                 primary will be fired first if the primary hasn't had a
                 previous value.  The primary data binding being the
                 location of the @{} expression.
      Bugs: SDK-21860
      Reviewer: Carol
      Cycloner: Gaurav
      Tests run: checkintests, mxunit databinding
      Is noteworthy for integration: No
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          Modified generateBindingsSetupFunction() to call
          generateIsTwoWayPrimaryAssignment() and added
          generateIsTwoWayPrimaryAssignment().
        modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          Modified emitBindingsSetup macro to set isTwoWayPrimary on the
          primary Binding of a two way data binding.
        modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
          Renamed isConstructTwoWay variable to isTwoWayPrimary and updated accessor.
        modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
        modules/compiler/src/java/flex2/compiler/mxml/builder/ServiceRequestBuilder.java
        modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
        modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraphBuilder.java
        modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
        modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
          Updated to reflect changes to BindingExpression.
        frameworks/projects/framework/src/mx/binding/Binding.as
          Added isTwoWayPrimary variable and modified execute() to call
          execute() on the twoWayCounterPart if there is one and hasHadValue
          is false.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21860
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/binding/Binding.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/ImplementationGenerator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AnonymousObjectGraph Builder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/ServiceRequestBuilde r.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/XMLBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/gen/ClassDefLib.vm
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/BindingExpression.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/rep/MxmlDocument.java
