1 Reply Latest reply on Sep 17, 2009 11:08 AM by Peter deHaan
    iPhone like lists - no visible scrollbar -
      I'd like to create a list that can be scrolled via the actual list contents like iPhone apps.
      How should I go about setting this up in Catalyst and anything I should handle in FLASH Builder?
      Any thoughts or suggestions welcomed.
        • 1. Re: iPhone like lists - no visible scrollbar -
          Peter deHaan Level 4
          You can disable the scrollbars on a Spark List control by setting the verticalScrollPolicy style on the List control's inner Scroller instance. You could do this using CSS:
                  @namespace s "library://ns.adobe.com/flex/spark";
                  s|List #scroller {
                      verticalScrollPolicy: off;
              <s:List id="list">
                      <s:VerticalLayout gap="0"
                                        requestedRowCount="5" />
                          <fx:Object label="One" />
                          <fx:Object label="Two" />
                          <fx:Object label="Three" />
                          <fx:Object label="Four" />
                          <fx:Object label="Five" />
                          <fx:Object label="Six" />
                          <fx:Object label="Seven" />
                          <fx:Object label="Eight" />
                          <fx:Object label="Nine" />
                          <fx:Object label="Ten" />
          Or you could create a custom skin for the List control and modify the Scroller instance there (and then set the skinClass style to your custom skin).
