0 Replies Latest reply on Sep 17, 2009 1:50 PM by deepa subramaniam (adobe)
    [svn:fx-trunk] 10355: Coordinated check-in of SDK and FXGUtils integration for the bitmap-related changes for FXG 2 .0 compliancy.
    deepa subramaniam (adobe) Level 2
      Revision: 10355
      Author:   dsubrama@adobe.com
      Date:     2009-09-17 13:50:21 -0700 (Thu, 17 Sep 2009)
      Log Message:
      Coordinated check-in of SDK and FXGUtils integration for the bitmap-related changes for FXG 2.0 compliancy. This includes several API changes documented below:
      1. BitmapGraphic is now BitmapImage in FXG. All this requires is changing the mapping in fxg-manifest.xml
      2. BitmapGraphic and BitmapFill's resizeMode property is renamed to fillMode
      3. BitmapResizeMode const class is now named BitmapFillMode
      4. BitmapFillMode's noScale enum is now called clip
      5. Border's backgroundImageResizeMode style is now called backgroundImageFillMode
      QE notes: Joan's updated tests
      Doc notes: Yes - the API renames needs to be reflected in the documentation
      Bugs: N/A
      Reviewer: Evtim for SDK, Corey for FXGUtils stuff
      Tests run: FXG static and runtime
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/frameworks/halo-manifest.xml
          flex/sdk/trunk/frameworks/mxml-manifest.xml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/CloseB uttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Grippe rSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacClo seButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacMax imizeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacMin imizeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Maximi zeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Minimi zeButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/Restor eButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/primitives/examples/BitmapImag eExample.mxml
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Border.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/BitmapImage.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/BorderSkin.as
          flex/sdk/trunk/frameworks/spark-manifest.xml
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGConstants.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/BitmapGraphicNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContentNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RectNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/BitmapFillNode. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextLeafNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/LinkNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/AbstractStrok eNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractCharacte rTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractTextNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/ResizeMode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/VerticalAlign.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXG_v1_0_Handler.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXG_v2_0_Handler.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ImageHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
      Added Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFillMode.as
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FillMode.java
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapResizeMode.as
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/FirstBaselineOf fset.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/types/LinkTarget.java
