3 Replies Latest reply on Sep 18, 2009 1:26 AM by shintashi
    is there an opposite to #include ?
    shintashi Level 1
      Question 1:
      Suppose I want to use #include "myfile.as, but with certain buttons or movieclips active, it becomes redundant or obsolete, or would interfere.
      Is there a way to "disinclude" that actionscript file once it's been added?
      Alternatively, are there tricks like "if(condition==true){#include "myfile.as"} ?
      Question 2:
      when loading text through loadvars, is there a way to clear what was loaded, or do I need to create a "blank" text file to load  and clear the screen?
        • 1. Re: is there an opposite to #include ?
          1.  no
          2.  you can't change what was loaded but you can delete or reassign the variable that originally stored your loadvars value.
          • 2. Re: About Reassigning Variables?
            shintashi Level 1
            In regard to Question 2:  "but you can delete or reassign the variable that originally stored your loadvars value"
            So this is basically what I was trying to do,
            --------------------------- CODE FOLLOWS -----------------------------
            htmlExpress = function(asFile, textFile){
            asFile = new LoadVars();
            asFile.onLoad = function(){
               myText_txt.htmlText = this.content;
            function react(menu_item, asFile, textFile){
                onMouseDown = function(){
                if(menu_item.hitTest(_root._xmouse, _root._ymouse, true)){htmlExpress(asFile, textFile);};}
            //htmlExpress(myData, "ghost.txt");
            onEnterFrame = function(){
            react(pl.A2.s1, myData, "web.txt");
            react(pl.A2.s2, myData, "ghost.txt");
            react(pl.A2.s3, myData, "max.txt");
            --------------------------- END CODE  -----------------------------
            in a nutshell, I push a button and a textfield loads the data of a textfile (with modest html tags like hyperlinks and italic text).
            If I push another button I was hoping it would change the textfield content to the new textfile, such as switching from web.txt to ghost.txt
            but that's not what happened. Instead, the react(blahblah.myData,"blah.txt"); that is closest to the bottom is the one that works. So if I had 27 of these buttons, #27 would work and the first 26 would not.
            • 3. Re: is there an opposite to #include ?
              shintashi Level 1
              managed to refine it somewhat:
              function react(menu_item, textFile){
              asFile.onLoad = function(){myText_txt.htmlText = this.content;}
              react(pl.A2.s3, "web.txt");
              react(pl.A2.s1, "ghost.txt");
              But it's got a weird glitch where it sometimes loads the text file because of the mousedown.
              I do not know how to tell it to stop detecting the mouse when the hitTest is false. I thought it would figure that out
              on it's own but clearly I was wrong.
