2 Replies Latest reply on Sep 18, 2009 6:24 AM by jefferisp7
    Is Admin a required table for ADDT login ?
    jefferisp7
      I created a simple database with 2 tables. One a record set of 2 values, price and rate
      the other was admin  with username and password.
      When I started the wizard, the connections came up with both tables properly named: admin and pricedata
      When I tried to use the admin table to create a login authorization, ADDT said "the admin table does not exist"    It listed it in the drop down but could not find the table with the connection.
      I then thought perhaps admin was a reserved word for a table so I recreated the table and renamed it "MyAdmin"  and I deleted ADDT files from the website and folder.  When I started to create the user login anew, the pricedata table still appears, but the other table is name "admin" not myadmin.  So I cannot use it to log in.
      Does ADDT require a table name admin to function??
      The other issue I wonder is that is earthlink's Mysql connection so slow that it is interfering with the connections. This is the client's host.... so it isn't my fault :-)
      Jeff
