0 Replies Latest reply on Sep 18, 2009 3:52 AM by Rupam K
    Difference between <compiler.source-path path-element="" /> & <source-path path-element="" />
    Rupam K Level 1
      Hi guys,
      I am not able to understand few differences when i am trying to compile my flex project using ANT. In the adobe resource i can see lots of places they mention as "compiler.source-path path-element="" "
      And lots of places i use as <source-path path-element="" />. Can anybody give a better explaination about this.
      The below example you can see there are lot of places where they used the attribute as compiler. & some places direct name
      <!-- myMXMLCBuild.xml -->
      <project name="My App Builder" basedir=".">
          <taskdef resource="flexTasks.tasks" classpath="${basedir}/flexTasks/lib/flexTasks.jar" />
          <property name="FLEX_HOME" value="C:/flex/sdk"/>
          <property name="APP_ROOT" value="apps"/>
          <property name="DEPLOY_DIR" value="c:/jrun4/servers/default/default-war"/>
          <target name="main">
              <mxmlc
                  file="${APP_ROOT}/Main.mxml"
                  output="${DEPLOY_DIR}/Main.swf"
                  actionscript-file-encoding="UTF-8"
                  keep-generated-actionscript="true"
                  incremental="true"
                  <!-- Get default compiler options. -->
                  <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml"/>
                  <!-- List of path elements that form the roots of ActionScript
                  class hierarchies. -->
                  <source-path path-element="${FLEX_HOME}/frameworks"/>
                  <!-- List of SWC files or directories that contain SWC files. -->
                  <compiler.library-path dir="${FLEX_HOME}/frameworks" append="true">
                      <include name="libs" />
                      <include name="../bundles/{locale}" />
                  </compiler.library-path>
                  <!-- Set size of output SWF file. -->
                  <default-size width="500" height="600" />
              </mxmlc>
          </target>
          <target name="clean">
              <delete dir="${APP_ROOT}/generated"/>
              <delete>
                  <fileset dir="${DEPLOY_DIR}" includes="Main.swf"/>
              </delete>
          </target>
      </project>
