0 Replies Latest reply on Sep 18, 2009 8:56 AM by Chet Haase
    [svn:fx-trunk] 10392: Fix for weird transition behavior when setting a component' s state from its container's state.
    Chet Haase Level 3
      Revision: 10392
      Author:   chaase@adobe.com
      Date:     2009-09-18 08:56:33 -0700 (Fri, 18 Sep 2009)
      Log Message:
      Fix for weird transition behavior when setting a component's state from its container's state. The fix is to defer the state setting that happens as part of SetProperty overrides, so that it only gets set to its final value, not transient values as the currentState gets removed and then applied.
      QE notes: None
      Doc notes: None
      Bugs: sdk-23251
      Reviewer: Corey
      Tests run: checkintests, Mustella spark/effects mx/states States
      Is noteworthy for integration: Yes, fix requested by downstream teams
      Ticket Links:
          http://bugs.adobe.com/jira/browse/sdk-23251
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/SetProperty.as
