3 Replies Latest reply on Sep 21, 2009 8:39 PM by bryn51
    Help for 'mdview'
    bryn51
      I am seeking documentation for 'mdview'
      Searched and found no results in online help and livedocs.
      What are its properties and methods ?
      <mdview:Order_Items_master
      id="
      masterView
      key="
      {this.key}
      width="
      600
      editItem="addEditItem(event);"
      addItem="addEditItem(event);"
      <mx:HRule width="100%"
        • 1. Re: Help for 'mdview'
          matthew horn Level 3
          I'm not familiar with this namespace or the class Order_Items_master. It's not part of the Flex framework. I assume this is from a third-party library?
          matt horn
          flex docs
          • 2. Re: Help for 'mdview'
            bryn51 Level 1
            order_items_master is a form within the application.
            This code was produced by the coldfusion/flex application wizard.
            mdview is not one of the canned class files included by the wizard, and so I assume that this is one of the flash/flex library classes, but cannot find documentation for it.
            I just want to know what properties, methods etc it has.
            Bryn Parrott
            • 3. Re: Help for 'mdview'
              bryn51 Level 1
              as it turned out, the cf/flex application wizard did this dirty trick on me:
              <cfComponents:SizeableTitleWindow
              xmlns:mx=http://www.adobe.com/2006/mxml
              xmlns:cfComponents="
              com.adobe.ColdFusion.components.*"
              width="
              100%" height="100%" explicitMaxHeight="{Application.application.height - 50}"
              title="
              Order Items"
              showCloseButton="
              true"
              close="WindowManager.remove(
              this);"
              xmlns:mdview="
              com.cfgenerated.views.masterdetail.*">
              And as you can see it has defined a namespace 'mdview' by way of 'xmlns', which I did not recognise (due to inexperience).
              Thanks for your help.
              Cheers,
              Bryn Parrott
