3 Replies Latest reply on Sep 21, 2009 12:11 PM by kglad
    PreLoad images
    AESS1981
      Hi, I have the following code to preload a set of images:
      pathToPics = "portfolio/2014/";
      var preLoader:MovieClip=this;
      var externalSWFs:Array=[pathToPics+"0.swf", pathToPics+"1.swf", pathToPics+"2.swf", pathToPics+"3.swf", pathToPics+"4.swf", pathToPics+"5.swf", pathToPics+"6.swf"];
      var loadTarget:Array = [preload0, preload1, preload2, preload3, preload4, preload5, preload6];
      var index:Number=0;
      loadNextSWF(index);
      function loadNextSWF(){
      if(index<externalSWFs.length){
      loadTarget[index].loadMovie(externalSWFs[index]);
      preLoader.onEnterFrame = preloadF;
      } else {
      delete preLoader.onEnterFrame;
      function preloadF(){
      var bl:Number=loadTarget[index].getBytesLoaded();
      var bt:Number=loadTarget[index].getBytesTotal();
      if(bl>0&&bl>=bt){
      preLoader["menu"+index].gotoAndPlay(1);
      index++;
      loadNextSWF();
      The swfs load perfectly in sequential order (ie. 0, 1, 2, 3, 4, 5, 6).
      The menu buttons ("menu"+index) are supposed to play in the same order as the swfs, but the order they play is:
      1 and 2 play at the same time, then 5, 6, 3, 4)
      The buttons are directly relevant to each image so the order is crucial.
      Is there a reason why this is happening?
