1 Reply Latest reply on Sep 20, 2009 11:38 AM by _gilado
    URLLoader POST binary data does not work
    _gilado Level 1
      I Place my swf and a file at the same location on a web server.
      The swf first downloads the file then uploads some data to another file.
      The download works fine. The upload does not start at all.
      As you can see in the below code I register a listenr for every event, none are called. Nor do I get any exception.
      I run wireshark and can see that no traffic is generated by the upload.
      I'm stumped.
              private var startUpload:Boolean = false;
              private var uploadUrl:String;
              private var uploadRequest:URLRequest;
              private var uploadLoader:URLLoader;
              private var uploadBytes:ByteArray;
              private var uploadStarted:Boolean = false;
              private var uploadDone:Boolean = false;
             public function upload(url:String):void
                  uploadStarted = false;
                  uploadDone = false;
                  uploadUrl = url;
                  uploadRequest = new URLRequest(uploadUrl);
      //          uploadRequest.method = URLRequestMethod.POST;
                  uploadRequest.method = "POST";
                  uploadRequest.contentType = "binary"; // need to find the right string
                  uploadRequest.data = uploadBytes;
                  uploadLoader = new URLLoader();
                  configureUploadListeners(uploadLoader);
                  uploadLoader.dataFormat = URLLoaderDataFormat.BINARY;
                  try {
                      uploadLoader.load(uploadRequest);
                  } catch (error:Error) {
                      statusError = "upload failed: " + error.message;
              private function configureUploadListeners(dispatcher:IEventDispatcher):void
                  dispatcher.addEventListener(Event.COMPLETE,uploadCompletedHandler);
                  dispatcher.addEventListener(Event.OPEN,uploadStartedHandler);
                  dispatcher.addEventListener(SecurityErrorEvent.SECURITY_ERROR,uploadSecurityErrorHandler) ;
                  dispatcher.addEventListener(HTTPStatusEvent.HTTP_STATUS,uploadHttpStatusHandler);
                  dispatcher.addEventListener(IOErrorEvent.IO_ERROR,uploadIOErrorHandler);
              private function uploadStartedHandler(event:Event):void
                  uploadStarted = true;
                  statusError += "Upload Started " + event;
              private function uploadCompletedHandler(event:Event):void
                  uploadDone = true;
                  statusError += "Upload Completed ";
              private function uploadSecurityErrorHandler(event:Event):void
                  statusError += "Upload SecurityError "; //(" + event + ")";
              private function uploadHttpStatusHandler(event:Event):void
                  statusError += "Upload HttpStatus "; //(" + event + ")";
              private function uploadIOErrorHandler(event:Event):void
                  statusError += "Upload IOError (" + event + ")";
        • 1. Re: URLLoader POST binary data does not work
          _gilado Level 1
          It now works! These are my changes to the above code
                      uploadRequest.contentType = "application/octet-stream";
                      uploadBytes = downloadBytes;
          downloadBytes is a ByteArray with the content of the downloaded binary file.
          I call the method with a url like this upload("http://www.mydomain.com/upload.cgi?upload_file_name");
          My upload.cgi looks like this
          #!/bin/bash
          echo "REQUEST_METHOD: $REQUEST_METHOD" > upload_log.txt
          echo "QUERY_STRING: $QUERY_STRING" >> upload_log.txt
          echo "CONTENT_LENGTH: $CONTENT_LENGTH" >> upload_log.txt
          echo "CONTENT_TYPE: $CONTENT_TYPE" >> upload_log.txt
          cat > $QUERY_STRING
          echo "Content-type: text/html"
          echo ""
          After uploadCompletedHandler executes, I find an exact py of the bytes in downloadbytes in a file called upload_file_name
