6 Replies Latest reply on Sep 21, 2009 2:31 AM by AESS1981
    track pIndex value in array
    AESS1981 Level 1
      I am using an array with a pIndex value of 0:
      this.pArray = ["1.swf", "2.swf", "3.swf", "4.swf"];
      this.pIndex = 0;
      Each time a button is pressed, the array number increases by 1:
      MovieClip.prototype.changeImage = function(d) {
      this.pIndex = (this.pIndex+d)%this.pArray.length;
      if (this.pIndex<0) {
      this.pIndex += this.pArray.length;
      I am trying to determine the pIndex value within the array, then use an 'if' statement to make certain mcs visible (depending on the value of pIndex). The following does not seem to work;
      if (this.pIndex = (this.pIndex=0)%this.pArray.length){
      menu1_wht._visible = true
      menu2_wht._visible = false
      menu3_wht._visible = false
      menu4_wht._visible = false
      I have also tried:
      if (this.pIndex =0) ...
      if (this.pArray[0]) ...
      Where am I going wrong?
      Thanks a lot
        • 1. Re: track pIndex value in array
          = is for assigning values.  When you are comparing values for equality in a conditional statement you use ==.
          And just for the record I still haven't wrapped my head around what is going on with this line of code:  (this.pIndex=0)%this.pArray.length
          You shouldn't have to determine the pIndex value in the array, it should be whatever value it is currently assigned, so all you probably need is...
          if (this.pIndex == 0){
          • 2. Re: track pIndex value in array
            AESS1981 Level 1
            Thanks Ned - this works initially.
            When the user loads a new image from the array, the pIndex number changes.
            What I cannot achieve is:
            Every time the pIndex number changes I need a different mc to become visible. I have tried:
            menu1_wht._visible = false
            menu2_wht._visible = true
            menu4_wht._visible = true
            else if (this.pIndex == 1){
            else if (this.pIndex == 2){
            menu3_wht._visible = true
            else if (this.pIndex == 3){
            I don't think the code traces the changing pIndex value.
            Is this possible?
            • 3. Re: track pIndex value in array
              I don't know why you are defining var using 'this', you should probably use var instead....
              var pArray = ["1.swf", "2.swf", "3.swf", "4.swf"];
              var pIndex = 0;
              If you don't think the code traces the pIndex value, just try tracing it and see.  Knowing what it is tracing will tell more than thinking it doesn't.
              Also, assuming the first set you show has one true too many, rather than the series of conditionals that you have, you can reduce that to the following....
              for(i=1; i<5; i++){
                   this["menu"+(i+1)+"_wht"]._visible = false; // hide all
              this["menu"+(pIndex+1)+"_wht"]._visible = true; // show the one
              • 4. Re: track pIndex value in array
                AESS1981 Level 1
                You are right, none of my code needed '.this'. I have removed all references to help tidy code.
                I love the simplicity of the code you have suggested for the mcs being visible or invisible but am still having issues at the last hurdle.
                The full code is below with the problem area in red bold. I have annotated as much as poss to assist. If you are able to look at it would be much appreciated:
                // Number menus default at invisible until associated image has loaded. //
                menu1.gotoAndStop("invisible");
                menu2.gotoAndStop("invisible");
                menu3.gotoAndStop("invisible");
                menu4.gotoAndStop("invisible");
                var pathToPics = "portfolio/100_design/";
                var fadeSpeedOut = 40;
                var fadeSpeedIn = 20;
                var pIndex = 0;
                // '_global.portfoliostate' tracks playhead position in timeline. //
                // Change the pArray[] value to target the relevant image. //
                // Change the pIndex= value to determine the position within the array. //
                if (_global.portfoliostate == "2_brand_identity"){
                loadMovie(pathToPics+pArray[1], _root.image_holder);
                pIndex = (pIndex=1)%pArray.length;
                else if (_global.portfoliostate == "3_promotional"){
                loadMovie(pathToPics+pArray[2], _root.image_holder);
                pIndex = (pIndex=2)%pArray.length;
                else if (_global.portfoliostate == "4_self_promotional"){
                loadMovie(pathToPics+pArray[3], _root.image_holder);
                pIndex = (pIndex=3)%pArray.length;
                else {
                loadMovie(pathToPics+pArray[0], _root.image_holder);
                // Individual functions for number buttons. //
                MovieClip.prototype.menuOne = function(d) {
                pIndex = (pIndex=0)%pArray.length;
                onEnterFrame = fadeOut;
                MovieClip.prototype.menuTwo = function(d) {
                MovieClip.prototype.menuThree = function(d) {
                MovieClip.prototype.menuFour = function(d) {
                // Functions for loading swfs into image gallery and controlling their behavior. //
                // make sure pIndex falls within pArray.length
                pIndex = (pIndex+d)%pArray.length;
                if (pIndex<0) {
                pIndex += pArray.length;
                MovieClip.prototype.fadeOut = function() {
                if (image_holder._alpha>fadeSpeedOut) {
                image_holder._alpha -= fadeSpeedOut;
                } else {
                loadPhoto();
                MovieClip.prototype.loadPhoto = function() {
                // specify the movieclip to load images into
                p = _root.image_holder;
                p._alpha = 0;
                trace(pathToPics+pArray[pIndex]);
                p.loadMovie(pathToPics+pArray[pIndex]);
                onEnterFrame = loadMeter;
                MovieClip.prototype.loadMeter = function() {
                i, l, t;
                l = image_holder.getBytesLoaded();
                t = image_holder.getBytesTotal();
                if (t>0 && t == l) {
                onEnterFrame = fadeIn;
                } else {
                trace(l/t);
                MovieClip.prototype.fadeIn = function() {
                if (image_holder._alpha<100-fadeSpeedIn) {
                image_holder._alpha += fadeSpeedIn;
                } else {
                image_holder._alpha = 100;
                onEnterFrame = null;
                // Track the pIndex value and make the relevant mc visible. //
                for(i=1; i<5; i++){
                ["menu"+(i+1)+"_wht"]_visible = false; // hide all
                ["menu"+(pIndex+1)+"_wht"]_visible = true; // show the one
                ends.
                Thanks so much for your efforts.
                • 5. Re: track pIndex value in array
                  In the example code I gave, "this" is meaningful to include, though you could use _root if that is applicable as well I suppose (I generally avoid _root references).
                  The way you have shown the code I have to assume is the way you have it coded in your file.  I would have thought that red code you highlighted would be within some function that responds to some action that changed the pIndex value, such as a button function.  Sitting at the end of the code as you have it, it will only execute one time when that frame is entered.
                  • 6. Re: track pIndex value in array
                    AESS1981 Level 1
                    Hey,
                    That makes sense what you have stated.
                    Unfortunately I am still struggling. On my 'next' button that loads the next swf I have:
                    on (release){
                    _root.changeImage(1);
                    for(i=1; i<5; i++){
                    _root["menu"+(i+1)+"_wht"]._visible = false; // hide all
                    _root["menu"+(pIndex+1)+"_wht"]._visible = true; // show the one
                    '_root.changeImage(1);' triggers the image change successfully but the visible / invisible doesn't seem to work.
                    I understand theoretically how it should work now, but am I missing anything?
                    Thank you
