3 Replies Latest reply on Sep 21, 2009 5:33 AM by Wade_Zimmerman
    Reset work space
    RotoRouter Level 1
      I am a nubie to Illo CS4 and in experimenting and scr..ing around with the application I think I have corrupted the workspace.
      Things are just not working properly.
      How do I reset the app back to defaults.
      TIA
      Chris
        • 1. Re: Reset work space
          Wade_Zimmerman Level 6
          Depends on what is going wrong several ways.
          1 Relaunch Illustrator and at the same time hold the command>option>shift on the  Mac on the pc hold the Control>Alt>shift keys down while the launch process is taking place.
          The other way is to trash the settings folder which is locate on the Mac in the Users/Username/Library/Preferences/Adobe Illustrator CS 4 Settings it is the last folder you trash
          on the PC it is located in the C drive/Documents and Settings/Username/Library/Preferences/Adobe Illustrator CS 4 Settings or do a search for it.
          It could just also be your workspace then you go to Windows>Workspace>Essentials which is the default.
          Trashing the settings folder or resetting the preferences will get you back to the way you started.
          • 2. Re: Reset work space
            RotoRouter Level 1
            A BIG 10Q again Wade.
            Cheers,
            Chris
            BTW where in the world are you? You seem to be in my time zone.
            • 3. Re: Reset work space
              NYC
