1 Reply Latest reply on Sep 20, 2009 9:34 PM by Adolfo Rozenfeld
    Converting footage - Image Sequence or Quicktime Movie
    Cris is Bliss Level 1
      Hello All
      Im on a Mac using CS4 suite, and my footage is in the format .MP4 Long GOP from a Sony EX 1.
      I've run into a couple of problems with Trimming/Consolidating projects in Premiere and in using Mocha because of the Long GOP.
      Since I don't wont to spend any more money on ANOTHER product plus learn ANOTHER application, I was thinking that I could just convert and replace my clips via the render queue or Media Encoder to a format that doesn't have problems.
      Previous info I got from the forum was: “Animation and PNG codecs in a QuickTime container as lossless interchange formats are good. The PNG codec is better for photorealistic images---like most video---whereas Animation is better at compressing large areas of the same color, like in a cartoon. (Hence the name, 'Animation'.)
      Apple Uncompressed 10 bit - when quality is utmost and you have plenty of drive space & speed
      Apple ProRes HQ - for near-lossless quality but smaller file sizes.”
      To further confuse me, I was reading in Mark Christiansen’s book AE CS4 Visual Effects, that a Sequence is better than Quicktime movie because of bad frame replacement ease and some other stuff about Quicktime formats inconsistent gamma.  But then in a sidebar he says Sequences may not play back so easily in you nonlinear editor. Nontheless, sequences are the best choice for larger or longer form projects.  ... and something about 10 bit uncompressed is only Lossless at 8bpc.  I haven’t gotten around to learning about 16 and 32 bpc and why or how I would be using it aside from a Video Co-Pilot tutorial on creaing Blooming by going beyond 255 white.  Then somebody mention Apple Pro Res because of 4 2 2 color space.
      HUH WHAT???????????????????????
      Some of these concepts are currently a bit over my head.  Basically I just want to be able to convert my footage without losing quaility to something that will work in AE (with Mocha) and can edit and consolidate in Premiere Pro.  What is the best to choose so that I don't lose ANY quality from the original footage.  File size is not an issue as I have plenty of HardDrive Space and will be consolidating.
      thanks
        • 1. Re: Converting footage - Image Sequence or Quicktime Movie
          Adolfo Rozenfeld Adobe Employee
          Hard drive space may not be an issue, but hard drive speed surely can be for HD content. Lossless or uncompressed formats require sustained speeds that may be well over 100 MB/s, which is beyond what a single disk can handle. That's why people who use such content rely on stripped disk arrays, ie multiple hard drives which are joined together as a single volume to provide this kind of disk performance.
          Other than that, there are some things which are platform specific.
          If you want to have real time editing on Premere Pro on Windows and also have great quality in AE, you could use the 8 Bit Yuv 4:2:2 codec which is available acrosss Adobe applications on Windows. This would require, again, a lot of disk horsepower. There's also a 10 bit version, but if your source footage is 8 bit (as XDCAM EX is) you'd be wasting bits (extra bit depth can always be good while processing images in the AE pipleine, not to fill bytes with empty informatiom that is not there when converting file formats).
          Quicktime Animation or Quicktime PNG would provide essentially the same quality on both platforms with smaller files, but neither of them is optimized to do real time editing.
          ProRes and Apple Uncompressed 8/10 bit are certainly great (the latter is exactly the same as YUV 4:2:2, but in a Quicktime container), but the problem is... there are free decoders for Windows and Mac, but you can only render to those codecs if you have Final Cut Studio in your machine.
          For most people using AE, real time decoding is not the main concern. In fact, most things you'd want to do in AE may be complex enough to make decoding speed less of an issue. That's why Quicktime PNG and Animation are so popular: they are free, reliable, cross-platform and offer uncompressed quality with somewhat smaller file sizes (ie, they are losssless). They just are not tuned for the kind of performance an editing application expects.
          If you'd like to have all that on Windows for real time edting on Premiere with regular hard drives, plus lossless quality in Premiere Pro and After Effects, it could be a good idea considering something like Cineform. But you may want to ask in the Premiere Pro forum if there's something else they recommend.
