0 Replies Latest reply on Sep 21, 2009 2:12 AM by v-Jay
    changing barseries label position on run time ?
    v-Jay Level 1
          Is it possible to change the label position for each bar series in bargraph depending on the label size.
      I am showing some values as label on barseries. As some time bar height is so small that lable truncates with inside position also with the bars of height max to lenear sacal labels with outside position truncates.
      Is it possible to set the label position on bars depending on label size or value its about to display. If value is large and can not fit inside bar then it should be set to position outside. Also with the bars of max height label positions should be set inside at runtime.
      Please reply if  having any suggestion or possible solution....
      Thanks in advance
