0 Replies Latest reply on Sep 21, 2009 5:58 AM by morten@mw-grafisk.dk
    Populate drop-down lists
      Greetings all, and thank you in advance for your time and expertise
      I have an AcroForm created in Acrobat 9.1 Pro with two drop-down lists which I need to populate with some information
      Background:
      Denmark is divided into five administrative region which is each divided into several smaller, municipal regions...
      The form has a drop-down field to provide either the name of the administrative region or the municipal region.
      If an administrative region is selected from the field 'Region_Text', the drop-down list containing the municipal regions should only display the municipal regions under the chosen administrative region
      AND
      If a municipal region is selected from the field 'Kommune_Text', the drop-down list containing the administrative regions should display the administrative region under which the municipal region belongs
      I hope this makes sense - All in all, two drop-down lists need to update each other
      Kind regards
      /Morten
