0 Replies Latest reply on Sep 21, 2009 8:42 AM by CoreyRLucier
    [svn:fx-trunk] 10459: Change to ensure ScriptNodes are no longer part of the node tree after interface compilation stage in order to avoid the extra code that was necessary to avoid tripping over them during type checking , etc.
    CoreyRLucier Adobe Employee
      Revision: 10459
      Author:   clucier@adobe.com
      Date:     2009-09-21 08:42:44 -0700 (Mon, 21 Sep 2009)
      Log Message:
      Change to ensure ScriptNodes are no longer part of the node tree after interface compilation stage in order to avoid the extra code that was necessary to avoid tripping over them during type checking, etc.
      Improving revision 10199 a bit, to allow for single line comments.
      QE notes: None
      Doc notes: None
      Bugs: SDK-22027
      Reviewer: Paul
      Tests run: Checking, Compiler cyclones
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22027
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/AbstractSyntaxTreeUtil.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/InterfaceCompiler.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/AbstractBuilder.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/builder/DocumentBuilder.java
