0 Replies Latest reply on Sep 21, 2009 10:40 AM by rfrishbe
    [svn:fx-trunk] 10464: Removing support in Flex framework for compatibility version < 3.
    rfrishbe Level 3
      Revision: 10464
      Author:   rfrishbe@adobe.com
      Date:     2009-09-21 10:40:30 -0700 (Mon, 21 Sep 2009)
      Log Message:
      Removing support in Flex framework for compatibility version < 3.  We won't support compatibility-version 2 or 2.01 anymore.  We only keep compatibility-version for one full release, so for Flex 4, we only support compatibility-version = 3.x.
      This should reduce our code-size some as we no longer need this old code.  I didn't clean up the compiler's support for compatibility-versioning as it didn't seem worth the effort.
      QE notes: -
      Doc notes: -
      Bugs: SDK-15360
      Reviewer: Kevin
      Tests run: checkintests, Joan ran all mustella tests
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-15360
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Accordion.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/FormItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/Panel.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/TabNavigator.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/accordionClasses/Accordion Header.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/CanvasLayou t.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/utilityClasses/Flex.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Alert.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Button.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/CheckBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ColorPicker.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DataGrid.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/LinkBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/LinkButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/List.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/MenuBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NavBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/NumericStepper.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/PopUpButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ProgressBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/RadioButton.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextArea.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/colorPickerClasses/SwatchPan el.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridHead er.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/dataGridClasses/DataGridHead erBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/ListItemRenderer .as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/TileListItemRend erer.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/menuClasses/MenuBarItem.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/menuClasses/MenuItemRenderer .as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/scrollClasses/ScrollBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/sliderClasses/Slider.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/treeClasses/TreeItemRenderer .as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UITextField.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/AccordionHeaderSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/DateChooserYearArrowSkin.a s
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/HaloBorder.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/PanelSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ScrollArrowSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/skins/halo/ScrollTrackSkin.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleManagerImpl.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProtoChain.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/styles/StyleProxy.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/core/UITLFTextField.as
