2 Replies Latest reply on Jul 30, 2008 12:20 AM by smscentral
    multiple Httpservice requests
    smscentral Level 1
      I have a requirement where i have to load two components on one click.
      And each component has httpservice request.
      function onclick is the following
      public function onclick(event:MouseEvent):void{
      this.loadComponentOne();
      this.loadComponentTwo();
      when i get the response correctly , the invoke and result events from httpservice are in this order
      Httpservice from component one in invoked
      result from component one is [object Object]
      HttpService from component two is invoked
      result from component two is [object Object]
      but sometimes there is a conflict between the responses from the httpservices of these components
      in this case,Events from httpservice output the result in this order
      result from component two is [] //empty for some reaon
      i get the result from my servlet correctly but ResultEvent.result is empty
      and the component two is not loaded because the result is empty..
      so how should the multiple httprequests be handled to get the responses correctly?
      chandana
        • 1. Re: multiple Httpservice requests
          atta707 Level 2
          you may want to show us more code. especially the event registration and handler code.
          • 2. Re: multiple Httpservice requests
            smscentral Level 1
            I am using a separate class to create a httpservice.
            following is the code where i send the Httpservice with all the event handlers.
            and from the component i call the methods from this class to get the response as follows
            public function selectedEntitiesList(id:String):void{
            backendRequest = new MittoBackendRequest(list_url);
            backendRequest.setRequest({action:action,id:id});
            backendRequest.addEventListener(ResultEvent.RESULT,getList);
            backendRequest.send();
            chandana
