3 Replies Latest reply on Sep 22, 2009 6:47 AM by ws1267
    menu and sub-menu
    kt03 Level 1
      Is anyone knows where to find an example for creating the menu and sub-menus in coldusion?
      thanks
      kt
        • 1. Re: menu and sub-menu
          ilssac Level 5
          Well here is one I currently use in one site.
          <ul id="menu">
            <li>Item 1</li>
            <li>Item 2</li>
            <li>Item 3</li>
          </ul>
          <ul>id="subMenu">
            <li>subItem 1</li>
            <li>subItem 2</li>
            <li>subItem 3</li>
          </ul>
          But then I wouldn't know why you would bother with ColdFusion for this.  But then I am guessing that you want something different, but your post gives absolutely no clue on what that something might be.
          • 2. Re: menu and sub-menu
            Adam Cameron. Level 5
            Some really obvious suggestions are:
            * Google "coldfusion menu".  There are quite a number of matches.
            * I imagine you could even search these forums or just read the recent posts.  I've been discussing this with another posted within the last week.
            * Do a bit of RTFM.  I suggest starting here, with the aptly named <cfmenu>: http://livedocs.adobe.com/coldfusion/8/htmldocs/Tags_m-o_04.html#2929198
            Adam
            • 3. Re: menu and sub-menu
              ws1267
              here is a simple example using cfmenu:
              <cfmenu name="menu" type="horizontal"
                       fontsize="14"  font="Verdana, Arial, Helvetica, sans-serif"  bgcolor="##ff9f40;"
                      selecteditemcolor="##dd6b04" selectedfontcolor="##FFFFFF" menustyle="border: 1;">
                  <cfmenuitem name="cfdiv" href="test1.cfm" display="Test1" />
                  <cfmenuitem name="cfdiv2"  href="test2.cfm" display="Test2"/>
                  <cfmenuitem name="JavaScripts"  display="JavaScripts">
                      <cfmenuitem name="test3" href="test3.cfm" display="test3"/>
                      <cfmenuitem name="test3a" href="test3a.html" display="test3a"/>
                  </cfmenuitem>
                  <cfmenuitem name="Examples"  display="Examples" >
                      <cfmenuitem name="cfgrid" href="cfgrid.cfm" display="CFGrid"/>
                      <cfmenuitem name="cfgridwin" href="cfgridwindow.cfm" display="CFgrid in Popup Window"/>
                      <cfmenuitem name="monthDay" href="ymd.cfm" display="day base on month selected"/>
                  </cfmenuitem>
                  <cfmenuitem name="cfmenu" href="http://tutorial16.learncf.com/demo/16" display="cfmenu on the fly"/>
              </cfmenu>
              hope it helps.
