0 Replies Latest reply on Sep 21, 2009 1:13 PM by rfrishbe
    [svn:fx-trunk] 10468: Forgot some stuff around compatibility-versioning support with my previous checkin , 10464.
    rfrishbe Level 3
      Revision: 10468
      Author:   rfrishbe@adobe.com
      Date:     2009-09-21 13:12:52 -0700 (Mon, 21 Sep 2009)
      Log Message:
      Forgot some stuff around compatibility-versioning support with my previous checkin, 10464.  Removing defaults-2.0.0.css and defaults-2.0.1.css.  Also, modified the compiler to spit out an error if you set compatibility-version=2.x since that's no longer supported for Flex 4.
      QE notes: -
      Doc notes: -
      Bugs: SDK-15360
      Reviewer: Corey
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/defaults-2
          http://bugs.adobe.com/jira/browse/SDK-15360
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/framework/.actionScriptProperties
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/projects/framework/build.xml
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/framework/defaults-2.0.0.css
          flex/sdk/trunk/frameworks/projects/framework/defaults-2.0.1.css
