1 Reply Latest reply on Sep 22, 2009 4:43 AM by ShardulSingh
    Update/edit xml with e4x
    rushbond
      Input xml is
      root>
           <node>
                <id>111</id>
                <name>aaa</name>
                <lname>bbbb</lname>
           </node>     <
      node>
                <id>222</id>
                <name>aaa1</name>
                <lname>bbbb1</lname>
           </node>     <
      node>
                <id>333</id>
                <name>aaa2</name>
                <lname>bbbb2</lname>
           </node></
      root>
      Expected ouput is
      root>
           <node>
                <id>000</id>
                <name>zzz</name>
                <lname>zzz1</lname>
           </node>     <
      node>
                <id>222</id>
                <name>aaa1</name>
           </node>     <
      node>
                <id>333</id>
                <name>aaa2</name>
           </node></
      root>
      I don't want to replace each child of node tag but replace entire node tag with id =111
      I am trying to use
      x1.node.(id==
      '111')=<node><id>000</id><name>zzz</name><lname>zzz1</lname></node>;
      not working
      Thanks in advance
        • 1. Re: Update/edit xml with e4x
          ShardulSingh Level 3
          Pls find the solution for your problem.Let me know if you have any issue.
          MainApplicaion.mxml
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="absolute">
          <mx:Script>
          <![CDATA[
          import mx.controls.Alert;
          private var xml : XML =
          <root>
          <node>
          <id>111</id>
          <name>aaa</name>
          <lname>bbbb</lname>
          </node>
          <node>
          <id>222</id>
          <name>aaa1</name>
          </node>
          <node>
          <id>333</id>
          <name>aaa2</name>
          </node>
          </root>
          private function onClick():void
          var childList : XMLList = xml.children() as XMLList;
          for each (var v : Object in childList )
          if(v.id == "111" )
          v.id = "000";
          v.name = "zzz";
          v.lname = "zzz1";
          Alert.show("This is the right outPut...." +"\n"+ xml);
          </mx:Script>
          <mx:Button label="Click Here to Get Your Expected OutPut xml" click="onClick()"/>
          </mx:Application>
          with Regards,
          Shardul Singh Bartwal
