5 Replies Latest reply on Jul 29, 2008 9:27 AM by Newsgroup_User
    xhtml tags and attributes
    gaurav_ch Level 1
      I was going through some xhtml reference text and found that there are many attributes to xhtml tags that i did not knew of. There were many tags which I never used. For eg., <big></big> and some attributes like <select dir=""></select>.
      What I want to know is that - do I really need to learn each and every attribute of an xhtml element or each and every tag that xhtml throws at me, from the point of interview or is it sufficient to know those attributes and elements which make me make accessible websites and validated markup?
      What do you all suggest?
      Gaurav
      www.gauravchandra.info
        • 1. Re: xhtml tags and attributes
          Level 7
          XHTML is built on HTML. As far as I know the tag set is the same. If you
          look here, you will not see an index item for "new tags" -
          http://www.w3.org/TR/xhtml1/
          <big> was part of HTML3.2.
          There is no dir attribute for the <select> tag.
          http://www.w3.org/TR/html401/interact/forms.html#h-17.6
          Validating the page?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          "gaurav_ch" <webforumsuser@macromedia.com> wrote in message
          news:g6mr3h$eep$1@forums.macromedia.com...
          > Hi,
          > many
          > which I
          > dir=""></select>.
          > me,
          > and
          > Gaurav
          > http://www.gauravchandra.info
          • 2. Re: xhtml tags and attributes
            Level 7
            .oO(gaurav_ch)
            >dir=""></select>.
            XHTML 1.0 is the same as HTML 4.01, just with stricter syntax rules.
            The supported elements and attributes are almost the same (there are
            some small differences, though, but in practice they won't matter much).
            Unless you have a very good reason to use XHTML, you should stay with
            HTML 4.01 Strict. Real XHTML doesn't work in the WWW yet, simply because
            Internet Explorer doesn't support it. You would have to write your XHTML
            in an HTML-compatible way and deliver it as HTML, so that IE will treat
            and render it as HTML ... pretty pointless. Real XHTML would just cause
            a download dialog in current IEs.
            Suggestion: Write proper and reasonable HTML 4.01 Strict, validate your
            markup/CSS and all will be happy.
            Micha
            • 3. Re: xhtml tags and attributes
              gaurav_ch Level 1
              Thank you all for replying. @Murray - Yes, you are right. There is no attribute "dir" for select tag. I read it in a book so I got confused and asked.
              @Michael Fesser - If IE does not support XHTML, this means that it is rendering it as HTML inspite of the XHTML DOCTYPE used in making pages? OMG!!! I really hate Microsoft for this. Thanks for telling me this. I never knew that.
              Still my question is unanswered - do I really need to learn each and every attribute of an xhtml element or each and every tag that xhtml throws at me, from the point of interview or is it sufficient to know those attributes and elements which make me make accessible websites and validated markup?
              Gaurav
              • 4. Re: xhtml tags and attributes
                Level 7
                > me,
                Has has already been said, XHTML is HTML with stricter tag syntax. If you
                know HTML (and to know HTML you should be familiar with ALL the tags), then
                you will be fine in XHTML (tag-wise, at least).
                news:g6ne7o$5m2$1@forums.macromedia.com...
                > Hi,
                > asked.
                > OMG!!!
                > that.
                > me,
                > and
                > Gaurav
                • 5. Re: xhtml tags and attributes
                  Level 7
                  .oO(gaurav_ch)
                  Exactly. IE accepts XHTML only if the server delivers it as text/html.
                  But then it's not really XHTML anymore.
                  Real XHTML should be delivered as application/xhtml+xml, which would let
                  modern browsers like Opera and FF use their XML parsers instead of the
                  old and bloated tagsoup parsers, but until now IE doesn't support this.
                  Not sure about the coming IE 8, though.
                  You should know at least most of the elements and attributes, so that
                  you can use them where appropriate. Same for CSS and its properties. Of
                  course you can't (and don't have to) remember them all. That's where a
                  quick reference guide or a "cheat sheet" comes in handy.
                  In my Opera browser for example I have these pages as sidebar panels for
                  a quick lookup (should also work in FF):
                  http://people.opera.com/rijk/panels/html4.01-online/elem.html
                  http://people.opera.com/rijk/panels/css2.1-online/prop-visual.html
                  Here are some more panels with previews:
                  You also might find some of these cheat sheets quite useful:
                  http://www.addedbytes.com/cheat-sheets/
                  Micha
