0 Replies Latest reply on Sep 23, 2009 3:10 AM by droom dp
    visible of layer
    droom dp
      I've troubles with a simple script in InDesign CS2, yes CS2, I do not have the opportunity to upgrade within this workflow.
      This is my script:
      repeat with myCounter from 1 to 20
      tell application "Adobe InDesign CS2"
          set visible of layer "myLayer" of active document to false
      end tell
      end repeat
      This script works fine when I run it from a script editor.
      This script is not working, nor generating an error, when I run it from the scripts panel.
      When I throw away the repeat block, everything is working again.
      Of course I need such a loop to run thru the pages of my document and depending on the page number, layers have to be visible or not.
      Anyone, any idea ?  Can somebody test this to see if this happens also on his configuration ?
      Kind Regards,
      Droom
