0 Replies Latest reply on Sep 22, 2009 4:50 AM by topmuffinsecret
    Dynamic DataGrid when XML is unkown
    topmuffinsecret
      Hello!
      I've got a problem with displaying xml in datagrid. After running  just column names are displayed.
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init()">
          <mx:Script>
              <![CDATA[
                  import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
                  import mx.controls.dataGridClasses.DataGridColumn;
                  import flash.net.URLLoader;
                  import flash.net.URLRequest;
                  import flash.events.*;
                  import flash.errors.*;
                  import mx.controls.*;
                  [Bindable] private var xmlList:XMLList = new XMLList();
                  private function init():void{
                      var xmlLoader:URLLoader = new URLLoader();
                      xmlLoader.addEventListener(Event.COMPLETE, xmlLoadComplete);
                      xmlLoader.load(new URLRequest("data/employees2.xml"));
                  private function xmlLoadComplete(evt:Event):void
                      try{
                          //get all the child elements of the root
                          xmlList = XML(evt.target.data).children();
                          //check to make sure there are results
                          if(xmlList.length() < 1){
                              Alert.show("There were no results that matched your search criteria");
                              return;
                          var dgCols:Array = new Array() ;
                          var xmlColumns:XMLList = xmlList;
                          for(var x:uint=0; x < xmlColumns.length(); x++){
                              var xml:XML = xmlColumns[x];
                              var col:DataGridColumn = new DataGridColumn();
                              col.headerText = xml.name();
                              col.dataField = xml.name();
                              col.labelFunction = scrubContent;
                              dgCols.push(col);
                          dgReport.columns = dgCols;
                          dgReport.dataProvider = xmlList;
                      }catch(e:Error){
                          Alert.show(e.message);
                  private function scrubContent(item:Object, col:DataGridColumn):String{
                      var xml:XML = XML(item);
                      var df:String = col.dataField;
                      return cleanHTML(decodeURI(xml.child(df)));
                  private function cleanHTML(str:String):String
                      var pattern:RegExp = /<TEXTFORMAT.*?>/g;
                      var str:String = str.replace(pattern, "");
                      pattern = /<FONT.*?>/g;
                      str = str.replace(pattern, "");
                      pattern = /<\/FONT.*?>/g;
                      pattern = /<P.*?>/g;
                      pattern = /<\/P.*?>/g;
                      pattern = /<\/TEXTFORMAT.*?>/g;
                      return str;
          </mx:Script>
          <mx:XML id="xmlDP" source="data/employees2.xml" />
          <mx:VBox id="vbox">
              <mx:DataGrid id="dgReport" width="600"/>
          </mx:VBox>
      </mx:Canvas>
      Simple xml file employees2.xml:
      <?xml version="1.0" encoding="UTF-8"?>
      <row>
         <firstName>
         Joe
         </firstName>
         <lastName>
         Jackson
         </lastName>
      </row>
