1 Reply Latest reply on Sep 23, 2009 2:50 PM by Joe ... Ward
    AIR PNG Encoder from Javascript.
      Hi there,
        How can I encode a Bitmap from AIR using the Javascript AIRAliases.js
          var captureFile = air.File.applicationStorageDirectory.resolvePath( 'c:\capture.png' );
          var capture = new air.BitmapData( window.htmlLoader.stage.stageWidth,window.htmlLoader.stage.stageHeight );
          capture.draw( window.htmlLoader );
          var image = new air.Bitmap(capture,"NEVER",false);
          var png = ???
        • 1. Re: AIR PNG Encoder from Javascript.
          Joe ... Ward Level 4
          AIR doesn't have a built-in PNG encoder. If you can find a JavaScript-based encoder you could use that.
          There are ActionScript encoders, including one in the Flex SDK. To use these, you would have to create a SWF that exposed a function to encode the PNG. You would then import that SWF into your application using a script tag.
          The code can be a simple as this:
              import flash.utils.ByteArray;
              import mx.graphics.codec.PNGEncoder;
              public class EncoderUtility
                  public static function encodePNG( bitmapData:BitmapData ):ByteArray
                      var encoder:PNGEncoder = new PNGEncoder();
                      var png:ByteArray = encoder.encode( bitmapData );
                      return png;
          You can compile it with the Flex + AIR SDK using the amxmlc compiler.
