5 Replies Latest reply on Sep 23, 2009 9:15 AM by kglad
    XML - Go to Frame of movie rather than URL
    mach6ix
      Hi Everyone,
      Thanks in advance for reviewing my post.
      I wish to code my XML file (which is for a news scrolling componenet) so when a specific word is clicked, it forwards the user to a specific frame within the same movie....and not a URL address.
      The XML code being used
      <b>Client Retention - The Bevinco Approach</b>
      <p>Review this informative video webinar featuring the Bevinco parnters from our Client Acquisition webinar. Review some of Bevinco's most successful partners client retention stratagies and tactics</p>
      <a class="link" href="http://members.section.com" target="_blank">Click <b>HERE</b> to view this informative video.</a>
      The area listed in RED, is the section of XML code I belive I need to modify.
      I've HIGHLIGHTED an example image below for futher clarification as well.
      I would like the user to click the word "HERE" and have it forward them to a specific frame of the same movie. Something like a gotoAndStop(50) command but for XML
      Any help is greatly appreciated.
      Cheers,
      Mike
        • 1. Re: XML - Go to Frame of movie rather than URL
          you'll use gotoAndStop(labelornumber) in your flash and place the label string or number in your xml.
          • 2. Re: XML - Go to Frame of movie rather than URL
            mach6ix Level 1
            Thanks for the reply K-Glad.
            However I'm not sure how to do what you are suggesting.
            I'm unaware about what you mean by placing a label string in my XML. Is it possible to provide an example via the code below?
            <a class="link" href="http://www.mywebsiteaddress.comhttp://members.section.com/" target="_blank">Click <b>HERE</b> to view this informative video.</a>
            I need to know if the "gotoAndStop" sit's in this Actionscript as this is the actionscript "tied" to this component.
            Is there a specific place that the "gotoAndStop" command should reside within the Actionscript?
            The actionscript being used by the news component is:
            function loadXML(loaded) {
                if (loaded) {
                    xmlNode = this.firstChild;
                    article = [];
                    description = [];
                    main = [];
                    total = xmlNode.childNodes.length;
                    for (i=0; i<total; i++) {
                        description[i] = xmlNode.childNodes[i].childNodes[0].firstChild.nodeValue;
                        main[i] = xmlNode.childNodes[i].childNodes[1].firstChild.nodeValue;
                    firstArticle();
                } else {
                    content = "file not loaded!";
            xmlData = new XML();
            xmlData.ignoreWhite = true;
            xmlData.onLoad = loadXML;
            xmlData.load("training.xml");
            /*var xmlData = new XML();
            xmlData.onLoad = function(success) {
            if (success) {
            main_txt.htmlText = xmlData.childNodes[0].childNodes[1].firstChild.nodeValue
            xmlData.load("training.xml");*/
            listen = new Object();
            listen.onKeyDown = function() {
            if (Key.getCode() == Key.LEFT) {
            prevArticle();
            } else if (Key.getCode() == Key.RIGHT) {
            nextArticle();
            Key.addListener(listen);
            previous_btn.onRelease = function() {
                prevArticle();
            next_btn.onRelease = function() {
                nextArticle();
            /////css for main text////
            p=0
            function firstArticle() {
                if (loaded == filesize) {
                    head_txt.text = description[0];
                    main_txt.htmlText = main[0];
                    article_num();
            function article_num() {
                current_pos = p+1;
                pos_txt.text = current_pos+" / "+total;
            function nextArticle() {
                if (p<(total-1)) {
                    p++;
                        head_txt.text = description[p];
                        main_txt.htmlText = main[p];
                        article_num();
            function prevArticle() {
                if (p>0) {
                    p--;
                    article_num();
            THANKS K-GLAD
            • 3. Re: XML - Go to Frame of movie rather than URL
              <a href="asfunction:gotoF, yourframelabel">Click <b>HERE</b> to view this informative video.</a>
              function gotoF(label:String){
              gotoAndStop(label);
              • 4. Re: XML - Go to Frame of movie rather than URL
                mach6ix Level 1
                K-GLAD
                You have been a fantastic help. This worked instantly with no trouble/trial and error.
                Greatly appreciated.
                "Who's the man?...K-GLAD's the man"
                • 5. Re: XML - Go to Frame of movie rather than URL
                  you're welcome.
