0 Replies Latest reply on Sep 22, 2009 10:35 AM by Carol L. Frampton
    [svn:fx-trunk] 10505: Update to TLF Build 516.
    Carol L. Frampton Level 2
      Revision: 10505
      Author:   cframpto@adobe.com
      Date:     2009-09-22 10:35:30 -0700 (Tue, 22 Sep 2009)
      Log Message:
      Update to TLF Build 516. See textLayout/ReleaseNotes.txt.
      Updated build file so the manifest for textLayout_edit is removed since TLF did it with their build file.
      QE notes:
      Doc notes:
      Bugs:
      Reviewer: Gordon asked me to do this
      Tests run: checkintests, TextInput, TextArea, RichText
      Is noteworthy for integration: yes
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/build.xml
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/BaseTextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlExporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/HtmlImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextConverter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_conversion/src/flashx/textLayout /conversion/TextLayoutImporter.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/manifest.xml
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/Build Info.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/BaseCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ComposeState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/ParcelList.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/SimpleCompose.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/StandardFlowComposer.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/compo se/TextFlowLine.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ColumnState.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/conta iner/ContainerController.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/debug /Debugging.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowGroupElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/FlowLeafElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/ParagraphElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/SpanElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TCYElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/ITextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TabStopFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/forma ts/TextLayoutFormatValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/EditC lasses.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/edit/ SelectionManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/textLayout/opera tions/DeleteTextOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_edit/src/flashx/undo/UndoManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkActiveFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkHoverFormat.as
          flex/sdk/trunk/frameworks/projects/textLayout/textLayout_core/src/flashx/textLayout/eleme nts/LinkNormalFormat.as
