4 Replies Latest reply on Nov 5, 2009 12:27 PM by paul.williams
    HTTPService result handler fires twice when called using AsyncToken
    shekel2000
      HTTPService is defined as:
      <mx:HTTPService id="recurrenceHttpService" url="http://localhost:8080/project/recurrence.ajax"
              method="GET" resultFormat="xml" useProxy="false" showBusyCursor="true"/>
      when i call an http service using:
      service.addEventListener(ResultEvent.RESULT, responder.result);
      service.addEventListener(FaultEvent.FAULT, responder.fault);
      service.send(params);
      (responder is an IResponer, params is an object with the parameters)
      The result is correct one call to the result handler.
      but when i call it using an AsyncToken:
      var token:AsyncToken = service.send(params);
      token.addResponder(responder);
      the result handler is called twice.
      This is the stack in both cases.
      first time:
          com.structures.commands::GenerateDatesForRecurrenceCommand/result
          mx.rpc::AsyncToken/http://www.adobe.com/2006/flex/mx/internal::applyResult
          mx.rpc.events::ResultEvent/http://www.adobe.com/2006/flex/mx/internal::callTokenResponders
          HTTPOperation/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent
          mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler
          mx.rpc::Responder/result
          mx.rpc::AsyncRequest/acknowledge
          DirectHTTPMessageResponder/completeHandler
          flash.events::EventDispatcher/dispatchEventFunction [no source]
          flash.events::EventDispatcher/dispatchEvent [no source]
          flash.net::URLLoader/onComplete [no source]
      Second Time:
          mx.rpc.http.mxml::HTTPService/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent
      ideas?
