1 Reply Latest reply on Sep 23, 2009 2:06 PM by Sean_Wilson
    detect and install quick time with lingo
    smaraki
      When I import a quick time movie into Director presentation - it needs QuickTime to be installed on every computer to run properly
      Is there any setting which may make these kind of movies run on any computer without QuickTime?
      Is there a Lingo script which may solve it?
      Otherwise is there any Lingo code to check for the presence of QuickTime and then react accordingly if the user doesn't have it installed ? (probably display a screen that offers to install QuickTime or quit the movie)
      any idea?
      Thanks a lot in advance.
      sof
        • 1. Re: detect and install quick time with lingo
          Sean_Wilson Adobe Community Professional
          No - if you want to display QuickTime movies (or use #quickTimeMedia members in Director) the playback machine must have QuickTime installed on it.
          There is the QuickTimeVersion() command (which you would have discovered if you had checked the Help file):
          on prepareMovie
            if QuickTimeVersion() < 7.0 then
              _player.alert("You need to install QuickTime - please re-start this program when the installer finishes")
              -- assuming the installer is in the same folder as the current movie/projector
              _player.open(_movie.path & "QuickTimeInstaller.exe")
              _player.quit()
            end if
          end
