Until recently I've been a relatively happy user of captivate for creating instructional materials - max 20 slides, audio, images, text and question slides.
Now I am finding that richer media is causing the programe to freeze on export or project preview. Currently I have a project for example with
- an embedded flash video
- several instances of animated text
- embedded swf animations (a box containing an approx 300 word scrolling text)
only 9 slides in the project
AS3, Flash 9
what seems to happen is previewing the project multiple times gradually corrupts the project somehow and after five or six previews it either freezes and crashes while trying to preview or publish the project.
The suggestion to copy and paste all the slides into a blank project was very helpful as it did work BUT of course this new project doesn't have all the same settings and loses the internal linking. Result - fixes + previews = crashing again. Very very frustrating.
Either
- there are a couple of settings I can watch out for to avoid or minimise this
- I cut out the rich media (no good from an instructional perspective)
- I limit certain types of media
or...?
Grateful for any help
Paul
If I were you I would drop the animation text parts. I have encountered quite a few issues with text animations and projects published with AS3.
I recently did some work for a client that had a massive course that had a lot of text animations and was published as AS3. All of the sudden none of their Captivate files worked any more and they couldn't view, preview or publish anything. The fix was to remove all the text animations and then the course worked perfectly well again.
/Michael
Visit my Captivate blog with tips & tricks, tutorials and Widgets.
Thanks Michael,
that's really helpful to know - if painful to accept
The client was quite excited about the possibilities of having a flash video side by side with scrolling tapescript (essential for non-English speakers to follow the content) but I guess we are in workaround country.
Paul
Hi there
In reading this thread it seems to me that you are each talking about different things. Paul seems to be talking about a Flash Animation (recorded using who knows what) that contains an area of scrolling text. Michael appears to be talking about Text Animations one may insert using Captivate.
If Michael's suggestion works for you, that's terrific and I'm pleased to see it solved the issue. But I remain a bit skeptical given that you seem to be talking about different things.
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Rick you are right. I am talking about the text animations from Captivate. Now that I read the post again I see that most likely Paul is talking about some externally developed flash animations containing some scrolling text.
Then it shouldn't be a problem at all to have that Flash content in the course. The problems I experienced are only related to the text animation feature in Captivate itself.
/Michael
Hi both
yes, thanks for pointing that out Rick. When you said 'text animation' Michael, I got confused as I was thinking of the 'dynamic text' feature in Flash which is used to get scrolling text in a swf.
I have been doing different types of diagnostics and I am beginning to suspect that the villain isnt the media I've been embedding (either flash movie or scrolling text inside a swf) but the overlayered table of contents. I didn't mention this before as I assumed that it was a standard part of the program.
Looks like if I don't enable the table of contents - a shame as it allows for a lot more learner autonomy - my projects work (3 out of 3 attempts haven't yet produced a crash on exporting ..)
Could that be it? Any comments on menus / table of contents making projects unstable?
Best
Paul
