2 Replies Latest reply on Sep 23, 2009 5:38 PM by Harm Millaard
    Anybody seeing degraded flv encoding in CS4?
      I'm getting significantly poorer quality using the CS4 Media encoder to derive and flv from an mov file, as compared to the same conversion using the CS3 flash encoder. Anybody else seeing this or have I missed a key setting somewhere?
      I often do edits in Premiere Pro and output both .mov and flv versions for maximum interoperability. When I had CS3, I would simply start the CS3 Flash encoder, add the output mov and convert... When I repeat the same process with the CS4 Media encoder, whether beginning from Premiere Pro or directly, I get a much lower quality result. I've tried to match settings:
      In CS3 Flash encoder - 'Video encoded for playback with Flash Player 8 or higher'
                     On2 VP6@700kbps
                     No audio
                     Encode alpha channel and deinterlace off
                     Quality: High
                     Max data rate 700 kbps
                     Frame rate 10 fps
                     Key Frame placement automatic
                     No resizing, etc
                     Same resolution (1030x893)
      In CS4 Media encoder:
                    On2 VP6
                    Encode alpha channel and resize vido off
                    Frame frate 10fps
                    Bit rate encoding: VBR, onepass, bit rage 1500 kbps
                    Set Key Frame difference and Simple Profile off
                    Quality Best
      In the CS4 version, fonts are blurred, curves are jagged, etc. Any thoughts?
