0 Replies Latest reply on Sep 23, 2009 6:27 PM by Carol L. Frampton
    [svn:fx-trunk] 10561: Halo ComboBox control did not look very good when using TLFTextField because the spark TextInput obscured the underlying button .
    Carol L. Frampton Level 2
      Revision: 10561
      Author:   cframpto@adobe.com
      Date:     2009-09-23 18:26:50 -0700 (Wed, 23 Sep 2009)
      Log Message:
      Halo ComboBox control did not look very good when using TLFTextField because the spark TextInput obscured the underlying button.  The TextInput border and background needed to be turned off.
      Rename ITextInput.showBorder(visible) to ITextInput.showBorderAndBackground(visible).  PARB approved.
      Remove TLFTextField from SparkClasses.  UITLFTextField will pull it in.
      QE notes:
      Doc notes:
      Bugs: SDK-23242
      Reviewer: Gordon
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23242
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ITextInput.as
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/mx/controls/TLFTextInput.as
