8 Replies Latest reply on Sep 25, 2009 12:15 AM by Yogi_ACE
    Plz help
    xcavan
      I am new to flex and have created a custom component. It is basically a popup through which you can select a date.
      <mx:TitleWindow
      xmlns:mx="http://www.adobe.com/2006/mxml
      layout="
      absolute
      title="
      Choose date
      showCloseButton="
      false
      width="
      132
      height="
      98" defaultButton="{winok}"
      <mx:Script>
      <![CDATA[
      public var
      rdate:Date;
      import
      mx.events.CloseEvent;
      import
      mx.managers.PopUpManager;
      private function titleWindow_close():void
      PopUpManager.removePopUp(
      this
      public function
      retdate():Date
      var
      date:Date = rdate;
      return
      date;
      private function init():
      void
      dtchsr.selectableRange={rangeStart:
      new Date(2007,0,0),rangeEnd: new
      Date()};
      </mx:Script>
      <mx:DateField id="dtchsr" change="{rdate = dtchsr.selectedDate}" formatString="DD/MM/YYYY" creationComplete="init()" x="0" y="0"
      <mx:ControlBar>
      <mx:Button label="OK" click="titleWindow_close()" id="winok"
      <mx:Button label="Cancel" click="titleWindow_close()" id="wincancle"
      </mx:ControlBar>
      </mx:TitleWindow>
      i tried using the popupmanager to deploy this window. but i am unable to retrive the date as the code keep on executing and retrives a null date.
      mywindow = PopUpManager.createPopUp(this, dtch, true) as
      dtch;
      dat = mywindow.retdate();
      teststring.text = dat.date.toString() +
      '/' + dat.month.toString() + '/'
      + dat.fullYear.toString();
        • 1. Re: Plz help
          Yogi_ACE Level 2
          If you have lack of time then simple way is to store value at your .mxml file
          <!-- Your .mxml file -->
          <mx:Script>
          <![CDATA[
                         public var dateRange:Date;
          </mx:Script>
          <!-- Component MXML -->
          on change you can set value as,
          Application.application.dateRange = dtchsr.selectedDate;
          And dateRange will be available through out your application. *(Remember it is work around and not the preferable solution)
          If this answer helps you then please mark it as answered.
          Best Regards,
          Yogesh
          • 2. Re: Plz help
            xcavan Level 1
            Dear Yogesh,
            Thanks for your reply...But now I am getting the following error:
            1119: Access of possibly undefined property dat through a reference with static type Class.   Diary/src/com dtch.mxml line 32 1253788129525 1241
            I am Building an AIR application.
            Regards,
            Saurav
            • 3. Re: Plz help
              Yogi_ACE Level 2
              what is there on:
              Can you share 4-5 lines around above and below line 32 from dtch.mxml?
              • 4. Re: Plz help
                xcavan Level 1
                <mx:TitleWindow
                layout="
                absolute
                title="
                Choose date
                showCloseButton="
                false
                width="
                132
                height="
                <mx:Script>
                <![CDATA[
                public var
                rdate:Date;
                import
                import
                this
                public function
                retdate():Date
                var
                date:Date = rdate;
                return
                date;
                void
                Date()};
                </mx:Script>
                <mx:DateField id="dtchsr" change="{Diary.dat = dtchsr.selectedDate; }" formatString="DD/MM/YYYY" creationComplete="init()" x="0" y="0"
                <mx:ControlBar>
                <mx:Button label="OK" click="Diary.fdiary(rdate); titleWindow_close()" id="winok"
                </mx:ControlBar>
                </mx:TitleWindow>
                Where Diary is my main mxml file.
                dat is the public variable
                and fdiary()  is a public function which take a date parameter
                • 5. Re: Plz help
                  Yogi_ACE Level 2
                  I am unable to find code at line 32 from dtch; text editor has added unwanted spaces and special characters to the code you have shared.
                  Instead of Diary.dat,
                  have you tried Application.application.dat?
                  • 6. Re: Plz help
                    xcavan Level 1
                    If i Replace Diary.dat with Application.application.dat i get the error:
                    1120: Access of undefined property Application. Diary/src/com dtch.mxml line 32 1253853982118 1300
                    line 32:
                    <mx:DateField id="dtchsr" change="{Application.application.dat = dtchsr.selectedDate; }" formatString="DD/MM/YYYY" creationComplete="init()" x="0" y="0"/>
                    If I use Diary.dat and change the var to static i dont get the error.
                    but agiain i have to access the function fdiary also, which cannot be made static.
                    • 7. Re: Plz help
                      xcavan Level 1
                      Thankyou very much..
                      I wasnt importin the mx.core.Application.....thus the error.
                      It is working finre now.
                      • 8. Re: Plz help
                        Yogi_ACE Level 2
                        Perfect!
