6 Replies Latest reply on Sep 24, 2009 9:32 AM by the_wine_snob
    Playback problem
    Buckeye101
      I have a Canon HG21 camcorder.  I've just burned my first DVD after some light editing with APE7.  Although the Panasonic DVD player indicates that it supports all types of disks (DVD-R, DVD - RW, etc) it tells me the disk is not formatted correctly.  I reformatted the disk & re-burned the file with the same result.  Any suggestions ??
        • 2. Re: Playback problem
          Buckeye101 Level 1
          Yes, APE7 = Adobe Premiere Elements 7.
          • 3. Re: Playback problem
            You say your DVD burner will work with DVD-R and DVD-RW -- but you're not using DVD+Rs, are you?
            If you're getting these types of messages, it's not related to Premiere Elements. It's something going on between your burner and your DVD media.
            • 4. Re: Playback problem
              the_wine_snob Level 9
              What exact type of media, and also the brand, are you using here?
              For some players, the "+" and "-" can make a difference. Newer players do not seem as prone to those differences, but they do still exist.
              Does your burned disc play on your computer through a DVD software player?
              • 5. Re: Playback problem
                Buckeye101 Level 1
                OK.  I'm recording to a Memorex DVD+RW  4x 4.7 GB 120 min.  My Panasonic DVD player says that it supports that media - as well as DVD-RW, etc.  I can play the DVD back through the computer - just not through the DVD player.
                Something else that I can't figure out, I have no sound when I am editing.  I do have sound when playing back the DVD through the computer.  (sorry for adding to the issues - I appreciate the help)  The computer is new - I did have sound when editing with my other computer.
                • 6. Re: Playback problem
                  Since this disc plays elsewhere, it is likely an incompatibility with the set-top player and that media.
                  Memorex is about the worst possible brand choice. They buy in bulk from the lowest bidder, and there may be a couple of different media in a 10 disc. spindle.
                  I am a big fan of Verbatim and Taiyo Yuden media.
                  Also, realize that no set-top player is required to play ANY burned disc. Most do, if burned properly, but many will not play any burned disc.
                  I also use +RW media, but only as a test, to keep from burning "coasters." I never use any rewritable for delivery. To date, I've never had an issue with any of my test players not playing a Verbatim RW disc. In your case, you might want to do a test burn to a non-rewritable disc, and test that with your set-top player.
