0 Replies Latest reply on Sep 24, 2009 8:32 AM by CoreyRLucier
    [svn:fx-trunk] 10571: "Simplified Skins" work items.
    CoreyRLucier Adobe Employee
      Revision: 10571
      Author:   clucier@adobe.com
      Date:     2009-09-24 08:32:20 -0700 (Thu, 24 Sep 2009)
      Log Message:
      "Simplified Skins" work items.  Defaulting useBaseColor to false for SparkSkin, added new script blocks to all Spark skins and tagged them with design time metadata such that Flash Builder can strip them when cloning.  Removed many instances of data binding from our skins and went with 'push' approach.
      QE notes: None
      Doc notes: None
      Bugs: N/A (4+ Work Item)
      Reviewer: Glenn
      Tests run: Mustella Cyclone
      Is noteworthy for integration: Yes, improves FB workflow when creating skins from existing templates (Spark).
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/SparkChromeWindowed ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/WindowedApplication Skin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/MacTit leBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/airframework/src/spark/skins/spark/windowChrome/TitleB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/SparkSkin.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSki n.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarDownButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarLeftButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarRightButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableContainerSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableDataContainerSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerDecrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerIncrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/FullSc reenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/MuteBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPa useButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/AccordionHeaderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarFirstButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarLastButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarMiddleButtonSki n.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ColorPickerSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderBackground Skin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderSeparatorS kin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextMonthSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextYearSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevMonthSkin .mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevYearSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/EditableComboBoxSkin.mxm l
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuArrow.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuArrowDisabled.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuCheck.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuCheckDisabled.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuRadio.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/MenuRadioDisabled.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PanelBorderSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PopUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarTrackSkin.mxm l
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarDownButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarUpButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TabSkin.mxml
          flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TextInputBorderSkin.mxml
