6 Replies Latest reply on Sep 25, 2009 7:31 AM by Mike6679
    Flex Desktop Application (export exe)
    Mike6679 Level 1
      How can I export an .exe file from a Flex Project?  I thought you right clicked on your project > select  Export  > choose Release Build. But I don't see an option in here for .exe (executable file).   I only see AIR option.
        • 1. Re: Flex Desktop Application (export exe)
          Ansury Level 3
          You can't build an exe with Flex.  What you CAN do is run Flex inside the AIR runtime, by creating files that have .air extensions.  But they execute just the same as exe files if you have the AIR runtime installed.
          • 2. Re: Flex Desktop Application (export exe)
            Mike6679 Level 1
            Thanks for the quick reply. So if I run the AIR file I export, will that in turn install an exe to my computer?
            • 3. Re: Flex Desktop Application (export exe)
              Ansury Level 3
              I haven't worked with AIR in awhile so I'm trying to recall... I believe it generates an install file for you. (might be an .airi file? I forget the extension)  After you install you won't have a .exe file, but a .air file.  When AIR runtime is installed however, .air files are double-clickable and will start up just like a .exe file, so as far as the user is concerned they are 'executables'.
              Not 100% sure I remembered the details right BUT the point is that if you create an AIR/Flex application you effectively have a standalone desktop executable application, which is what you want.  Flex either runs in a browser with the Flash VM, or standalone/installed in an AIR VM (which I imagine has the Flash VM code in it).
              • 4. Re: Flex Desktop Application (export exe)
                Ansury Level 3
                But I should specify - you have to create your initial project as an AIR application, rather than a Flex/web based application when you create the project.
                • 5. Re: Flex Desktop Application (export exe)
                  EgorKDie Level 2
                  The .air file is effectively just a custom zip file that the AIR installer uses to create the application on the users machine.
                  It includes an exe, which is tiny and only seems to serve to start the runtime and throw the associated SWF to it.
                  Important point, THE EXE IS NOT THE APPLICATION!!! The swf is.
                  AIR 2.0 promises a new installer style btw... If you install the AIR app using a native installer, there is no need for the .air file.
                  • 6. Re: Flex Desktop Application (export exe)
                    Mike6679 Level 1
                    Thanks all for your quick and detailed answers!  I hadn't done much with desktop apps in Flex, just web apps in Flex, so this info has been very helpful.  I think there is a way to generate an exe from an AIR file as well ( http://forums.adobe.com/thread/103563)  .
