1 Reply Latest reply on Jul 25, 2008 3:39 PM by
    Export AS2 Drawing For Print?
      Hi, I'm new to the whole concept of drawing with code, and I would like to know if anyone could help me.
      I have made an actionscript drawing that draws itself when I test the movie, how do I export the drawing as a print quality file (300 dpi), if I take a picture from my desktop it's at 72 dpi, which does not work for what I'm trying to do.
      When I try to publish it as a PNG, it is just a blank picture.
      Any help or suggestions are appreciated.
        • 1. Re: Export AS2 Drawing For Print?
          Hey, check out http://www.joshuadavis.com/workshop/ He has instructions on how to rip swf files for print, although the link doesn't seem to be working. You need to run your flash file then right click (ctrl click on mac) and choose print. Format for Adobe PDF and then hit ok. After you hit ok you will see pdf in the bottom corner....click there and choose save pdf as postscript. You can open the postscript file in illustrator and export from there.
          Hope this helps.
