2 Replies Latest reply on Sep 25, 2009 10:45 AM by lee704
    Bind two DataGrids so that a change in one will be refelected in another
    lee704 Level 1
      Is there a simple way to bind two DataGrids so that a change in one will be refelected in another?  I have two DataGrids.  One will be editable and the other will be used to display the information from the editable DataGrid in a confirmation section.  Is there a simple example  out there for doing this?
      Lee
        • 1. Re: Bind two DataGrids so that a change in one will be refelected in another
          Flex harUI Adobe Employee
          Yes, but it depends on how your data is organized.  If you have a central ArrayCollection, both DG's should use that as the dataProvider.  If you don't you can try to find a way to assign the dataProvider.list to the dataProvider of the other DG.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: Bind two DataGrids so that a change in one will be refelected in another
            lee704 Level 1
            I may have figured it out.  It seems to be working with:
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
            layout="absolute"
            creationComplete="initComponent()"
            xmlns:views="com.views.*"
            width="100%"
            height="100%">
            <mx:Script>
            <![CDATA[
            import mx.collections.ArrayCollection;
            import mx.rpc.events.ResultEvent;
            private var currentIndex:int=0;
            private function initComponent():void
            refreshList(null);
            public function refreshList(event:Event):void
            this.roArtist.getArtists();
            private function getArtists_result(event:ResultEvent):void
            dgArtistList.dataProvider=event.result as ArrayCollection;
            dgArtistList.selectedIndex=currentIndex;
            dgArtistListConfirm.dataProvider=event.result as ArrayCollection;
            dgArtistListConfirm.selectedIndex=currentIndex;
            </mx:Script>
            <mx:RemoteObject id="roArtist"
            showBusyCursor="true"
            destination="ColdFusion"
            source="art.src.cfc.artist">
            <mx:method name="getArtists"
               result="getArtists_result(event)">
            </mx:method>
            </mx:RemoteObject>
            <mx:Label x="10"
              y="10"
              text="Entry"
              fontWeight="bold"/>
            <mx:DataGrid id="dgArtistList"
            x="10"
            y="36"
            editable="true">
            <mx:columns>
            <mx:DataGridColumn dataField="ARTISTID"
               headerText="ArtistID"
               editable="false"/>
            <mx:DataGridColumn dataField="FIRSTNAME"
               headerText="First Name"
               editable="true"/>
            <mx:DataGridColumn dataField="LASTNAME"
               headerText="Last Name"
               editable="true"/>
            </mx:columns>
            </mx:DataGrid>
            <mx:Label x="10"
              y="210"
              text="Confirmation"
              fontWeight="bold"/>
            <mx:DataGrid id="dgArtistListConfirm"
            x="10"
            y="236" dataProvider="{ArrayCollection}">
            <mx:columns>
               headerText="ArtistID"/>
               headerText="First Name"/>
               headerText="Last Name"/>
            </mx:columns>
            </mx:DataGrid>
            </mx:Application>
            I need to do some testing.
            Thanks!
