3 Replies Latest reply on Sep 30, 2009 2:25 AM by FranciscoSalasHortelano
    binding node value from public var
      I am developing an interface between an axis web service and flex.
      I must create a custom soap message, so I have define:
      CDATA
      [Bindable] public var name:String = "PRUEBAS";
          <mx:request xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                    xmlns:xsd="http://www.w3.org/2001/XMLSchema"
                    xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
                     xmlns:loc="http://XXXXXXXXX/"
                    xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
                         format="xml">
               <loc:DarWeb soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
               <in0 xsi:type="loc:Elem" xmlns:dat="http://XXXXXX">
                  <original xsi:type="xsd:string">{name}</original> IT DOES NOT TAKE THE VALUE OF THE BINDING VAR
             </in0>
      Please, someone who knows how to get the value of the var?
      PD: In compilation time I have the next warning:  "data binding will not be able to detect assignments to ..."
      Thanks in advance
      Fran
        • 1. Re: binding node value from public var
          paul.williams Level 4
          Its hard to say from the source snippets you've posted. A full mxml / actionscript file that demonstrates the problem would be more helpful.
          My main concern is that UIComponent has a 'name' property which is not bindable, so I'd suggest changing the name of your public variable to avoid any confusion.
          • 2. Re: binding node value from public var
            FranciscoSalasHortelano Level 1
            Thanks for your reply williams. I will try to explain better.
            I have an action script class called Name with the next attribs:
              public class Name
                     [Bindable] public var name:String;
                     [Bindable] public var ape1:String;
                     [Bindable] public var cp:String;
                  public function Name()
                              //nothing initialize
            In my mxml I have
            <mx:Script>
                <![CDATA[
                [Bindable] public var nombre:Name = new Name();
            </mx:Script>
            And the last code that are involve in my problem is the next one:
            <mx:WebService id="webService" wsdl="XXXX (local wsdl)" showBusyCursor="true">
                <mx:operation name="getNames"
                            resultFormat="e4x"
                            result="handleResponse(event);"
                            fault="handleFault(event);">
                          xmlns:name="http://XXXXXXX"
                               format="xml">
                          <name:getNames soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                               <in1 xsi:type="name:Name" xmlns:name="http://XXXXXX">
                                  <name xsi:type="xsd:string"> {nombre.name}</name><!-- value from class-->
                                  <ape1 xsi:type="xsd:string">{nombre.ape1}</ape1><!-- value from class-->
                                  <cp xsi:type="xsd:string">{nombre.cp}</cp><!-- value from class-->
                               </in1>
                       </name:getNames>
                     </mx:request>
                      </mx:operation>
                </mx:WebService>
            I can not retrieve class attribute´s values, so the xml nodes are null.
            Thanks a lot for those who reply.
            Fran
            • 3. Re: binding node value from public var
              Hi at all,
              I have solved my problem binding node values from bindable attributes.
              I have constructed a local xml var, and when I called the webservice it is passed as parameter like this:
              var xml:XML = new XML (
                                 </in1>
                         </name:getNames>
              webservice.operation.send(xml);
              If I intercept the soap message with a sniffer NOW I CAN SEE THE VALUES OF THE BINDING NODES.
              Thanks at all, and remember not include a xml with binding into mx:request. Pass it as parameter when call the ws operation.
              Fran
