15 Replies Latest reply on Sep 25, 2009 8:25 PM by andykrug
    AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
    andykrug
      Just spent 3 hours on tech support in India reagrding AVCHD and premier 4.1 - plus about 2 weeks in Panasonic Engineering-
      I have a Panasonic HMC 150 and could not play the footage (strobe like plus mosaic- explaining that to a foreign laguage I think went OK- )
      The tech support manager has "escalated" this as of Wed Sept 23rd because he has had "100 calls about this recenty". I have sent test footage to Panasonic engineering for confirmation of "clean footage" and that was confimed Monday Sept 21st. I then viewed a training segement on Adobe TV Tuesday by Dave Helmly and he was importing HMC 150 footage onto a OS 10.5.6 --- 2.93 GHz Intel Core 2 Duo with 8 gig memory- and it was perfect. I am running 3.06 Ghz and 4 gig memory (which Dave stated as not a problem in the training) Hoping to open the conversation to other users to solve this. If anyone can put us in touch with Dave that would be great.
        • 1. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
          pebalsamo Level 2
          I have not had any stobing problems with mine.  I am on Windows XP Pro 64, 8gb ram, 2.6ghz core 2 quad.
          If I am playing the video for a while it may get a little stroby or if I am playing multiple streams, but for ht emost part it is OK.  Scrubbing thorough the video is not nearly as smooth as other formats.  Next computer build will be much heftier and will hopefully handle AVCHD better.  The one thing about AVCHD and Premiere that really makes me crazy is that it does not support Timecode...  Lots of emails back and forth with India trying to get them to figure it out.  ADOBE's tech support REALLY STINKS!!!!!!
          Phil
          • 2. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
            andykrug Level 1
            wow, thanks for contacting me - where are you located - I may need to get a
            project off my plate since you can edit AVCHD
            Andy Krueger
            Mountain Video Productions LLC
            Mailing Address: PO Box 515 Telluride CO 81435
            Shipping Address: 2905 San Bernardo Dr Telluride CO 81435
            Phone and Fax 970-728-7008
            www.mountainvideoproductions.com
            www.coolsculpt.com
            • 3. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
              pebalsamo Level 2
              I am in St Louis Mo...
              If you want to send me a clip to take a look at I can, just to make sure that there is not something goofy with your camera...
              What kind of project is it that you are working on?
              Phil
              www.videoviews.com
              • 4. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                pebalsamo Level 2
                Another place to check is over at the HMC forum.  I have not seen any mention of a problem like yours, but that does not mean that someone over there has not seen it...
                http://www.dvxuser.com/V6/forumdisplay.php?f=146
                Phil
                • 5. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                  andykrug Level 1
                  The scoop is my first  step was I went through Panasonic engineering to
                  confirm the footage was clean- I sent a test chip with the same settings as
                  the shoot and it was confirmed "clean" . The project is just a wedding
                  video- but I am not one to fail a job....
                  Do you shoot with the Panasonic 150 and edit on Premier 4.1????
                  Andy Krueger
                  www.coolsculpt.com
                  • 6. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                    dsladek Level 1
                    If you can post a link to a short clip, I'll have a look at it in PP CS4.
                    I've just finished another project for a client who gave me 108 .MTS files.
                    Dennis Sladek
                    • 7. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                      dradeke Adobe Employee
                      Have you tried the standard things to resolve the problem?
                      1. update your graphics driver
                      2. make sure you have the latest update on Premiere Pro (currently 4.1)
                      3. clean the media cache in Premiere Pro
                      4. trash the preferences folder
                      5. uninstall/reinstall (with running CS4 clean script)
                      I probably have all of Dave's AVCHD material and I do not have any problems playing it on either Mac or PC.
                      Hope this helps,
                      Dennis
                      • 8. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                        andykrug Level 1
                        thanks so much- forging forward
                        Andy Krueger
                        www.coolsculpt.com
                        • 9. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                          andykrug Level 1
                          thanks for this also- I'm on it
                          Andy Krueger
                          www.coolsculpt.com
                          • 10. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                            pebalsamo Level 2
                            Yes we shoot with the Panny 150 and edit with Premiere 4.1.
                            Most of what we shoot is 720p60, but I have shot with most of the other setting too without problem.  Have you tried converting the footage to DVCPROHD with the free utility from Panasonic?  Maybe worth a try to see if you computer is just having a hard time with the AVCHD stuff and then you would know that it is not the actual clip but something with your machine...
                            Phil
                            • 11. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                              dsladek Level 1
                              Have you already tried Steps 1- 5 as Dennis Radeke suggested?
                              • 12. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                                andykrug Level 1
                                I am on Mac
                                    I have a Nvidia Ge Force 8800GS. When I could not find a mac driver
                                version at the Nvidia' site (the archives say  that is only for windows....)
                                I called Apple Care and we thought it was strange - but the supervisor said
                                that it automatically updates.(as best as I could understand the
                                communication.
                                2. make sure you have the latest update on Premiere Pro (currently 4.1)--
                                got it
                                3. clean the media cache in Premiere Pro - Ugh don not know how to do that-
                                did not find that it "help" tab
                                4. trash the preferences folder -- I think - the adobe help hade me create a
                                new user and still had the problem
                                5. uninstall/reinstall (with running CS4 clean script)  - I do not know what
                                clean script is....
                                Thanks so much for contacting me
                                Andy Krueger
                                www.coolsculpt.com
                                • 13. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                                  andykrug Level 1
                                  Thanks Phil- I sent a test chip with all the formats recorded to Panasonic
                                  Engineering and the said it was "perfect"
                                  Do you edit on Mac???
                                  Andy Krueger
                                  www.coolsculpt.com
                                  • 14. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                                    communication.
                                    - Yes, that's correct.  Sorry, don't always look as to what platform...
                                    got it
                                    Preferences>Media and then there should be a button.  This probably won't fix it, but it can't hurt.
                                    Mac: UserDocuments>Adobe>Premiere Pro.. Take the 4.0 folder and drag it to your desktop.  This is the prefs file.  When you launch Premiere Pro, it will create a new version.
                                    clean script is....
                                    CS4 Clean Script
                                    No problem.
                                    Andy Krueger
                                    www.coolsculpt.com
                                    • 15. Re: AVCHD Panasonic HMC-150 and Premier 4.1 - Escalated problem
                                      andykrug Level 1
                                      I have a call time 6 am tomorrow- will dive in Sunday- have a great weekend
                                      Andy Krueger
                                      www.coolsculpt.com
