7 Replies Latest reply on Nov 2, 2009 10:45 AM by larry_schwartz
    Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
    larry_schwartz
      When working with AdvancedDataGridRendererProvider in an Advanced Datagrid -- Is it possible for renderer code to reference the columnIndex parameter of the AdvancedDataGridRendererProvider?
      Thanks.
        • 1. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
          paul.williams Level 4
          Not sure I fully understand what you are trying to do, but if you want to get the columnIndex from code within a renderer then take a look at the AdvancedDataGridListData class and the IDropInListItemRenderer interface:
          http://livedocs.adobe.com/flex/3/langref/mx/controls/advancedDataGridClasses/AdvancedDataG ridListData.html
          http://livedocs.adobe.com/flex/3/langref/mx/controls/listClasses/IDropInListItemRenderer.h tml
          • 2. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
            larry_schwartz Level 1
            I appreciate your answer, but I'm really not sure how to implement it.
            I'm trying to write a renderer that I can reuse for all columns in my datagrid.
            The code in it is conditional based on the specific column it is currently being used on.
            So, for example, if I have 10 AdvancedDataGridColumns in an AdvancedDataGrid, each with their dataField being "TheCol01", "TheCol02", "TheCol03", etc., I know I can explicitly reference the column in the renderer with the code:
            data['TheCol09']
            However, this way, I'd have to write 10 different renderers.
            What I'm looking for is a way, within the renderer, to determine the "columnIndex" parameter of the AdvancedDataGridRendererProvider tag that called the renderer. This way, for example, I could have conditional code like:
            switch(columnIndex)
                 case 1:
                      myVarValue = data['TheCol01'];
                      //Now do something only relevant to the data in TheCol01
                      break;
                 case 2:
                      myVarValue = data['TheCol02'];
                      //Now do something only relevant to the data in TheCol02
                      break;
                 case 3:
                      myVarValue = data['TheCol03'];
                      //Now do something only relevant to the data in TheCol03
                      break;
            Does this help explain what I'm trying to do?
            Thank you.
            • 3. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
              I've attached two examples that use properties of AdvancedDataGridListData so that they can be reused in different columns. The first is an MXML example that extends Canvas and uses bindings to set text and tooltip on a Label control. The second achieves similar functionality in ActionScript by extending UIComponent. The tooltip displays some of the information that is available to you via the AdvancedDataGridListData object.
              The AdvancedDataGrid will inject an instance of AdvancedDataGridListData into any item renderer that implements the IDropInListItemRenderer interface. In order to implement this interface you use the 'implements' keyword when declaring the class and add getters and setters for the listData property. I've done this for each renderer in the example.
              While the MXML example is simpler, the ActionScript example should perform better.
              • 4. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
                Thanks so much for these examples, I appreciate the help. I'll dig in and let you know how it goes.
                • 5. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
                  Thanks so much for the code.  It was exactly what I needed.  Once I saw it I completely understood what you were doing.
                  • 6. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
                    GeorgeWS Level 1
                    Can you post the code, I cannot seem to save or open the .zip
                    • 7. Re: Advanced DataGrid - Renderers - Possible to reference the columnIndex parameter?
                      //*** START ActionScriptRenderer.as
                      package
                          import mx.controls.Label;
                          import mx.controls.advancedDataGridClasses.AdvancedDataGridListData;
                          import mx.controls.listClasses.BaseListData;
                          import mx.controls.listClasses.IDropInListItemRenderer;
                          import mx.controls.listClasses.IListItemRenderer;
                          import mx.core.UIComponent;
                          public class ActionScriptRenderer
                              extends UIComponent
                              implements IListItemRenderer, IDropInListItemRenderer
                              private var _label : Label;
                              private var _data : Object;
                              private var _listData : BaseListData;
                              private var _listDataChanged : Boolean = true;
                              public function set data( value : Object ) : void
                                  _data = value;
                              public function get data() : Object
                                  return _data;
                              public function set listData(
                                  value : BaseListData ) : void
                                  _listData = value;
                                  _listDataChanged = true;
                                  invalidateProperties();
                              public function get listData() : BaseListData
                                  return _listData;
                              protected override function createChildren() : void
                                  super.createChildren();
                                  _label = new Label();
                                  addChild( _label );
                              protected override function commitProperties() : void
                                  super.commitProperties();
                                  if ( _listDataChanged &&
                                      _listData != null )
                                      _label.text = listData.label;
                                      _label.toolTip = getToolTip();
                                      _listDataChanged = false;
                              protected override function updateDisplayList(
                                  unscaledWidth : Number,
                                  unscaledHeight : Number ) : void
                                  super.updateDisplayList(
                                      unscaledWidth,
                                      unscaledHeight );
                                  _label.move( 0, 0 );
                                  _label.setActualSize(
                                      unscaledWidth,
                                      unscaledHeight );
                              private function getToolTip() : String
                                  var adgListData : AdvancedDataGridListData =
                                      AdvancedDataGridListData( _listData );
                                  var result : String = "";
                                  result += "Label: " + adgListData.label + "\n";
                                  result += "Column Index: " + adgListData.columnIndex + "\n";
                                  result += "Data Field: " + adgListData.dataField + "\n";
                                  result += "Data Field Value: " + adgListData.item[ adgListData.dataField ] + "\n";
                                  result += "Row Index: " + adgListData.rowIndex + "\n";
                                  result += "Depth: " + adgListData.depth + "\n";
                                  result += "Has Children: " + adgListData.hasChildren;
                                  return result;
                      //*** END ActionScriptRenderer.as
                      //*** START ListDataDemo.mxml
                      <mx:Application
                          xmlns:mx="http://www.adobe.com/2006/mxml"
                          layout="vertical">
                          <mx:Script>
                              <![CDATA[
                                  import mx.collections.ArrayCollection;
                                   [Bindable]
                                   private var dpADG:ArrayCollection = new ArrayCollection([
                                     {Artist:'Pavement', Album:'Slanted and Enchanted', Price:11.99},
                                     {Artist:'Pavement', Album:'Brighten the Corners', Price:11.99},
                                     {Artist:'Saner', Album:'A Child Once', Price:11.99},
                                     {Artist:'Saner', Album:'Helium Wings', Price:12.99},
                                     {Artist:'The Doors', Album:'The Doors', Price:10.99},
                                     {Artist:'The Doors', Album:'Morrison Hotel', Price:12.99},
                                     {Artist:'Grateful Dead', Album:'American Beauty', Price:11.99},
                                     {Artist:'Grateful Dead', Album:'In the Dark', Price:11.99},
                                     {Artist:'Grateful Dead', Album:'Shakedown Street', Price:11.99},
                                     {Artist:'The Doors', Album:'Strange Days', Price:12.99},
                                     {Artist:'The Doors', Album:'The Best of the Doors', Price:10.99}
                          </mx:Script>
                          <mx:Label
                                 text="MxmlRenderer"
                                 color="#ffffff"
                                 fontWeight="bold"/>
                          <mx:AdvancedDataGrid
                              height="250"
                              width="500"
                              rowHeight="25"
                              dataProvider="{ dpADG }">
                              <mx:columns>
                                  <mx:AdvancedDataGridColumn
                                      dataField="Artist"/>
                                      dataField="Album"/>
                                      dataField="Price"/>
                              </mx:columns>
                              <mx:rendererProviders>
                                  <mx:AdvancedDataGridRendererProvider
                                      renderer="MxmlRenderer"
                                      columnIndex="0"/>
                                      columnIndex="1"/>
                                      columnIndex="2"/>
                              </mx:rendererProviders>
                          </mx:AdvancedDataGrid>
                             <mx:Label
                                 text="ActionScriptRenderer"
                                 color="#ffffff"
                                 fontWeight="bold"/>
                              height="250"
                              width="500"
                              rowHeight="25"
                              <mx:columns>
                                      dataField="Album"/>
                                      dataField="Price"/>
                              </mx:columns>
                                      renderer="ActionScriptRenderer"
                                      columnIndex="0"/>
                                      columnIndex="1"/>
                                      columnIndex="2"/>
                      </mx:Application>
                      //*** END ListDataDemo.mxml
                      //*** START MxmlRenderer.mxml
                      <mx:Canvas
                          implements="mx.controls.listClasses.IDropInListItemRenderer">
                          <mx:Script>
                              <![CDATA[
                                  [Bindable]
                                  public function set listData( value : BaseListData ) : void
                                      _listData = value;
                                      return _listData;
                                      listData : BaseListData ) : String
                                          AdvancedDataGridListData( listData );
                                      return result;
                          </mx:Script>
                          <mx:Label
                              id="canvasLabel"
                              text="{ _listData.label }"
                              toolTip="{ getToolTip( _listData ) }"/>
                      </mx:Canvas>
                      //*** END MxmlRenderer.mxml
