0 Replies Latest reply on Sep 25, 2009 4:01 PM by Evtim Georgiev (Adobe)
    [svn:fx-trunk] 10606: White space cleanup.
    Evtim Georgiev (Adobe) Level 2
      Revision: 10606
      Author:   egeorgie@adobe.com
      Date:     2009-09-25 16:01:50 -0700 (Fri, 25 Sep 2009)
      Log Message:
      Doc notes: None
      Bugs: None
      Reviewer: Evtim
      Tests run: build
      Is noteworthy for integration: Nope
      Modified Paths:
          flex/sdk/trunk/development/eclipse/flex/sparkTest/src/testWheel.mxml
          flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ArrayList.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/collections/ListCollectionView.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/containers/ViewStack.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/ComboBox.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/VideoDisplay.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/scrollClasses/ScrollBar.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/AdvancedLayoutFeatures.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Container.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/core/LayoutElementUIComponentUtils.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/Effect.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/effects/EffectManager.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/CompoundTransform.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/Transform.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/geom/TransformOffsets.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/BitmapFill.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/graphics/GradientBase.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/states/AddItems.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/DescribeTypeCache.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/MatrixUtil.as
          flex/sdk/trunk/frameworks/projects/framework/src/mx/utils/OnDemandEventDispatcher.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DataGroup.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/DropDownList.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Scroller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/DropDownCont roller.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableCom ponent.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ToggleButton Base.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/AnimateTransform.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/effects/supportClasses/AnimateTransfor mInstance.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/BasicLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/TileLayout.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/Block.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/layouts/supportClasses/LinearLayoutVec tor.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/primitives/Path.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/SparkSkin.as
