0 Replies Latest reply on Sep 25, 2009 7:20 PM by SunWuKonga
    Referencing XML object fields with descendent accessor (..)
    SunWuKonga
      This works:
           var example:XML =     <result type="success">
                                    <products>
                                         <product>...</product>
                                    </products></result>;
           for each(var item:XML in example..product)
      as does the following: (My hackneyed solution)
           for each(var item:XML in XML(JavaServiceHandler(e.currentTarget).response.toString())..product)
      Note that the explicit cast using JavaServiceHandler() is not necessary. The target Object e.currentTarget of type JavaServiceHandler has a public field variable
           public var response:XML;
      This call:
           JavaServiceHandler(e.currentTarget).response.toString();
      returns a string that exactly matches the var example:XML above, in fact 'example' is a copy and paste.
      However, this does NOT work:
           for each(var item:XML in JavaServiceHandler(e.currentTarget).response..product)
      nor this:
           for each(var item:XML in XML(JavaServiceHandler(e.currentTarget).response)..product)
      nor this:
           for each(var item:* in JavaServiceHandler(e.currentTarget).response..product)
      nor this:
           for each(var item:* in (e.currentTarget).response..product)
      Does anyone know why?
