7 Replies Latest reply on Jul 29, 2008 8:52 AM by TimEm
    Paragraph After a Snippet
    TimEm Level 1
      I have snippet in RH7 which when inserted in the topic looks fine I close the topic and re open it a a blank paragraph has been inserted after the snipet.
      Code for snipper below:
      <!doctype HTML public "-//W3C//DTD HTML 4.0 Frameset//EN">
      <html><head>
      <meta http-equiv=content-type content="text/html; charset=utf-8">
      <meta name=generator content="Adobe RoboHelp - www.adobe.com">
      <meta name=generator-major-version content=0.1>
      <meta name=generator-minor-version content=1>
      <meta name=filetype content=RoboHelp>
      <meta name=filetype-version content=1>
      <meta name=page-count content=1>
      <meta name=layout-height content=922>
      <meta name=layout-width content=1271>
      <title>Run SET</title>
      </head>
      <body>
      <p class=topic-text-numbered><a href="Run_SET.htm">Run SET</a><span style="x-condition: Print;">
      as described in the ‘Run SET’ section of this manual.</span></p>
      </body>
      </html>
      The snippet apperars in a numberd list.
        • 1. Re: Paragraph After a Snippet
          Snippets have to be paragraphs. See David Locke's article on Adobe's site.
          • 2. Re: Paragraph After a Snippet
            TimEm Level 1
            Hi thanks for your comment. I thought my snippet was a paragraph it is enclosed in a <p> tag. What confuses me is that when I first insert the snippet it looks fine in both the editor and preview see below.
            First Line
            Snippet
            Next line
            Next line
            After I save, close, and reload the topice it looks like this;
            First Line
            Snippet
            Next line
            Next line
            • 3. Re: Paragraph After a Snippet
              Kayelllae
              I'm having the same problem...
              • 4. Re: Paragraph After a Snippet
                Hi all
                If you are displaying paragraph markers you will notice that inserting a snippet does indeed add an additional paragraph between the snippet and the following text. To my knowledge, it's only a frustrating thing and you may simply delete the offending or unwanted paragraph marker following the snippet. Personally, these aren't zombified on my PC. By that, I mean that they don't seem to spontaneously come back from the dead zone after closing and re-opening the topic.
                Cheers... Rick
                • 5. Re: Paragraph After a Snippet
                  TimEm Level 1
                  Hi
                  Unfortuantely the paragraph reappears after saving and re-opening the opic. I have other snipets in the same project that work fine.
                  • 6. Re: Paragraph After a Snippet
                    Have you tried deleting the snippet using the option not to delete references to it and then creating a new version. Backup the project first.
                    • 7. Re: Paragraph After a Snippet
                      TimEm Level 1
                      Hi
                      I have created a new project using the default style sheet. And created a similar snippet. the problem occurs every time.
                      When I place th snippet it puts 2 paragraph s after it I deleted them all looks fine. save and reopen the topic and one has returned. TEh snipper is being insert in a <ol>tag.
                      When it is displayed OK the HTML looks like this
                      <ol><li class=p><p>This is the first topic in your project. Delete this
                      text and replace it with your own. To add a new topic, click the <b>New
                      Topic </b>button on the tool bar.</p></li>
                      <li class=p><placeholder id="snippet_test"></li>
                      After saving and reopening it looks like this:
                      <li class=p>
                      </li>
                      RH7 is adding
                      I just noticed it also does this as I swap between Design view and HTML view
