3 Replies Latest reply on Sep 27, 2009 8:43 AM by kglad
    loadMovie issue
      I am trying to load an external swf at a specific x& y pos. from a button. This is the code I am using :
      on (release) {gotoAndPlay(4);
      xpos="7", ypos="119";
      The movie loads fine if I remove xpos="7", ypos="119";
      How do I get it to load at that specific position??
        • 1. Re: loadMovie issue
          if you're going to load into a _level you should use loadMovieNum.  in addition, to change the target _level to your desired x,y you need to wait until loading is complete.
          you'll probably find it's easier to load into a target movieclip because you don't have to wait until loading is complete to assign the desired x,y:
          • 2. Re: loadMovie issue
            uptoppapi Level 1
            loadMovie-1.jpgThaloadMovie-2.jpgnk you. U have me on the right track, but..the code moved the swf to the right x and y pos, but the swf seems to be moved incomplete. check out file I sent.
            Any thoughts?
            • 3. Re: loadMovie issue
              that's not the code i suggested.  i explicitly recommended you NOT load into a _level.
              use the code i gave.
