3 Replies Latest reply on Sep 27, 2009 9:21 AM by John Joslin
    CS4 Bridge can't see CS3 Photoshop's ACR
    JohnEwing
      Hi all, I have been using CS3 PS + ACR happily for the last year.  Yesterday I downloaded the CS4 trial packs for Dreamweaver, Flash, etc, and installed them, along with CS4 Bridge.
      CS4 Bridge will send an image to CS3 PS but when I select "Open in Camera Raw" it tells me I have to "launch a qualifying product at least once to include this feature".
      Que pasa?
      Fortunately, CS3 Bridge is still available, and still has all its cups in the cupboard; but it's rather inconvenient running both.
      I would be grateful for any suggestions,
      John Ewing
        • 1. Re: CS4 Bridge can't see CS3 Photoshop's ACR
          John Joslin Level 6
          With that combination you are likely to run into several problems, particularly with file associations and ACR compatibility.
          Why didn't you get the trial of PS CS4 too?
          • 2. Re: CS4 Bridge can't see CS3 Photoshop's ACR
            JohnEwing Level 1
            Hi John, thanks for the reply.  I'm considering adding CS4 Web Standard to my toolkit and I just downloaded the trial components.  I was chary of getting PS CS4 trial because I didn't want to break any CS3 license parameters in the registry if I let the trial period run out.  The upgrade is $199 in the US, but it's nearly 300 euros here, which is significant money just to restore a compatibility.
            File associations are no problem, and ACR probably has no issues with Bridge unless they've made major changes to the interface, which I doubt.  I think it's more likely to be a simple question of one product seeing the other one's licensing rights in the registry.
            JohnE
            • 3. Re: CS4 Bridge can't see CS3 Photoshop's ACR
              John Joslin Level 6
              There is an Adobe Clean Script which will remove all traces of the trial.   CS4 Clean Script.
              I really think you'll get in a mess with versions mixed up like that!
              There are major changes to Bridge and ACR and I really advise you not to get yourself and the computer in a muddle.
