2 Replies Latest reply on Sep 28, 2009 1:16 PM by Techfu
    Long startup and save times for Fc
    Techfu
      Its taking almost 5-7mins to open my FXP file (file size 256MB). I think Im running a pretty decent machine Intel Duo Core 2.4GHz, 2.4GHz with 4GB memory.
      It also take a long time to save the file - almost 7mins. And often the Fc instance crashes with out of memory and Java null pointer errors.
      I know this is beta version, but if you can give me some tips to cut down on these lengthy times will be greatly appreciated.
      thanks,
      Fu
      Here is the content of generated error file:
      # An unexpected error has been detected by Java Runtime Environment:
      #  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x38713d71, pid=4448, tid=4368
      # Java VM: Java HotSpot(TM) Client VM (1.6.0_01-b06 mixed mode)
      # Problematic frame:
      # C  [AdobeSWFL.dll+0x273d71]
      # If you would like to submit a bug report, please visit:
      #   http://java.sun.com/webapps/bugreport/crash.jsp
      ---------------  T H R E A D  ---------------
      Current thread (0x00396400):  JavaThread "main" [_thread_in_native, id=4368]
      siginfo: ExceptionCode=0xc0000005, writing address 0x00000000
      Registers:
      EAX=0x00000000, EBX=0x00100000, ECX=0x00008000, EDX=0x00000000
      ESP=0x00139524, EBP=0x00139528, ESI=0x0019281c, EDI=0x00000000
      EIP=0x38713d71, EFLAGS=0x00010206
      Top of Stack: (sp=0x00139524)
      0x00139524:   00000000 00139548 38713dde 00000000
      0x00139534:   00400000 00010001 00000000 000000a0
      0x00139544:   00000000 00000000 388a7705 00000000
      0x00139554:   00000000 00400000 00400000 6c570000
      0x00139564:   0019281c 00100000 5641ec70 00100000
      0x00139574:   6c570000 388a77b7 5641e000 5641ec70
      0x00139584:   00192728 49d52b58 388a5b71 5641ec70
      0x00139594:   49d52b58 37dc06d0 5641ec70 50cb2b61
      Instructions: (pc=0x38713d71)
      0x38713d61:   e9 07 66 0f ef c0 eb 08 8d a4 24 00 00 00 00 90
      0x38713d71:   66 0f 7f 07 66 0f 7f 47 10 66 0f 7f 47 20 66 0f
      Stack: [0x00040000,0x00140000),  sp=0x00139524,  free space=997k
      Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
      C  [AdobeSWFL.dll+0x273dde]
      Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
      J  com.adobe.flexide.embeddedplayer.PlayerNatives.CallActionScript(ILjava/lang/String;)Ljava /lang/String;
      J  com.adobe.flexide.embeddedplayer.ExternalPlayer.callFunction2(Ljava/lang/String;)Ljava/la ng/String;
      J  com.adobe.thermo.core.remoteobject.OutgoingCommandHandler.call(Ljava/lang/String;Ljava/la ng/String;[Ljava/lang/Object;)Ljava/lang/Object;
      j  com.adobe.thermo.interfaces.GenericModelProxyInterface.endUpdate()V+14
      j  com.adobe.thermo.models.UIModelSharingAdapter.refresh()V+42
      j  com.adobe.thermo.models.UIModelSharingAdapter.currentModelChanged()V+138
      j  com.adobe.thermo.models.UIModelSharingAdapter.framePopped(Lcom/adobe/thermo/core/workspac e/IDesignStackFrame;)V+1
      j  com.adobe.thermo.core.workspace.DesignStack.notify(Lcom/adobe/thermo/core/workspace/IDesi gnStackFrame;Z)V+49
      j  com.adobe.thermo.core.workspace.DesignStack.pop()Lcom/adobe/thermo/core/workspace/IDesign StackFrame;+80
      j  com.adobe.thermo.core.workspace.WorkspaceManager.close()V+13
      j  com.adobe.thermo.core.fxp.FXPCommands.deleteAllProjects()Z+107
      j  com.adobe.thermo.application.ThermoAppWorkbenchAdvisor.preShutdown()Z+14
      j  org.eclipse.ui.internal.Workbench.busyClose(Z)Z+5
      j  org.eclipse.ui.internal.Workbench.access$15(Lorg/eclipse/ui/internal/Workbench;Z)Z+2
      j  org.eclipse.ui.internal.Workbench$23.run()V+13
      j  org.eclipse.swt.custom.BusyIndicator.showWhile(Lorg/eclipse/swt/widgets/Display;Ljava/lan g/Runnable;)V+116
      j  org.eclipse.ui.internal.Workbench.close(IZ)Z+20
      j  org.eclipse.ui.internal.Workbench.close()Z+3
      j  org.eclipse.ui.internal.WorkbenchWindow.busyClose()Z+52
      j  org.eclipse.ui.internal.WorkbenchWindow.access$0(Lorg/eclipse/ui/internal/WorkbenchWindow ;)Z+1
      j  org.eclipse.ui.internal.WorkbenchWindow$3.run()V+9
      j  org.eclipse.ui.internal.WorkbenchWindow.close()Z+14
      j  org.eclipse.jface.window.Window.handleShellCloseEvent()V+6
      j  org.eclipse.jface.window.Window$3.shellClosed(Lorg/eclipse/swt/events/ShellEvent;)V+19
      j  org.eclipse.swt.widgets.TypedListener.handleEvent(Lorg/eclipse/swt/widgets/Event;)V+231
      J  org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/swt/widgets/Event;)V
      J  org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;Z)V
      j  org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;)V+4
      j  org.eclipse.swt.widgets.Decorations.closeWidget()V+12
      j  org.eclipse.swt.widgets.Decorations.WM_CLOSE(II)Lorg/eclipse/swt/internal/win32/LRESULT;+ 28
      J  org.eclipse.swt.widgets.Control.windowProc(IIII)I
      J  org.eclipse.swt.widgets.Canvas.windowProc(IIII)I
      J  org.eclipse.swt.widgets.Decorations.windowProc(IIII)I
      J  org.eclipse.swt.widgets.Shell.windowProc(IIII)I
      J  org.eclipse.swt.widgets.Display.windowProc(IIII)I
      v  ~StubRoutines::call_stub
      J  org.eclipse.swt.internal.win32.OS.DefWindowProcW(IIII)I
      J  org.eclipse.swt.widgets.Shell.callWindowProc(IIII)I
      J  org.eclipse.swt.internal.win32.OS.DispatchMessageW(Lorg/eclipse/swt/internal/win32/MSG;)I
      J  org.eclipse.swt.widgets.Display.readAndDispatch()Z
      J  org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptio nHandler;Lorg/eclipse/swt/widgets/Display;)V
      j  org.eclipse.ui.internal.Workbench.runUI()I+393
      j  org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
      j  org.eclipse.ui.internal.Workbench$5.run()V+23
      j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databindin g/observable/Realm;Ljava/lang/Runnable;)V+12
      j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display; Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
      j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/ecl ipse/ui/application/WorkbenchAdvisor;)I+2
      j  com.adobe.thermo.application.ThermoApplication.start(Lorg/eclipse/equinox/app/IApplicatio nContext;)Ljava/lang/Object;+149
      j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Objec t;+135
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Ob ject;)Ljava/lang/Object;+103
      j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Lja va/lang/Object;+29
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object; +149
      j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnabl e;)Ljava/lang/Object;+183
      j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object; [Ljava/lang/Object;)Ljava/lang/Object;+0
      j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/l ang/Object;+87
      j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Lja va/lang/Object;+6
      j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+ 161
      j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+21 1
      j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+114
      j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
      ---------------  P R O C E S S  ---------------
      Java Threads: ( => current thread )
        0x359ba400 JavaThread "Worker-8" [_thread_blocked, id=5704]
        0x358fe800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5984]
        0x3560c400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4432]
        0x35199000 JavaThread "Thread-12" [_thread_in_native, id=5672]
        0x35137400 JavaThread "Worker-6" [_thread_blocked, id=2000]
        0x35191000 JavaThread "Worker-2" [_thread_blocked, id=952]
        0x338e2000 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=2716]
        0x338e4800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=4976]
        0x32e8bc00 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3620]
        0x32e87000 JavaThread "CompilerThread0" daemon [_thread_blocked, id=1892]
        0x32e85c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=1848]
        0x32e84c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=5724]
        0x32e73800 JavaThread "Finalizer" daemon [_thread_blocked, id=3144]
        0x32e72800 JavaThread "Reference Handler" daemon [_thread_blocked, id=5284]
      =>0x00396400 JavaThread "main" [_thread_in_native, id=4368]
      Other Threads:
        0x32e6f400 VMThread [id=3580]
        0x32e96400 WatcherThread [id=4064]
      VM state:not at safepoint (normal execution)
      VM Mutex/Monitor currently owned by a thread: None
      Heap
      def new generation   total 36288K, used 29774K [0x02af0000, 0x05250000, 0x05250000)
        eden space 32256K,  92% used [0x02af0000, 0x047ee460, 0x04a70000)
        from space 4032K,   2% used [0x04e60000, 0x04e756c8, 0x05250000)
        to   space 4032K,   0% used [0x04a70000, 0x04a70000, 0x04e60000)
      tenured generation   total 483968K, used 403021K [0x05250000, 0x22af0000, 0x22af0000)
         the space 483968K,  83% used [0x05250000, 0x1dbe34a8, 0x1dbe3600, 0x22af0000)
      compacting perm gen  total 65536K, used 53749K [0x22af0000, 0x26af0000, 0x32af0000)
         the space 65536K,  82% used [0x22af0000, 0x25f6d5a0, 0x25f6d600, 0x26af0000)
      No shared spaces configured.
      Dynamic libraries:
      0x00400000 - 0x0040e000  C:\Program Files\Adobe\Adobe Flash Catalyst\Adobe Flash Catalyst.exe
      0x7c900000 - 0x7c9b2000  C:\WINDOWS\system32\ntdll.dll
      0x7c800000 - 0x7c8f6000  C:\WINDOWS\system32\kernel32.dll
      0x7e410000 - 0x7e4a1000  C:\WINDOWS\system32\USER32.dll
      0x77f10000 - 0x77f59000  C:\WINDOWS\system32\GDI32.dll
      0x5d090000 - 0x5d12a000  C:\WINDOWS\system32\COMCTL32.dll
      0x77dd0000 - 0x77e6b000  C:\WINDOWS\system32\ADVAPI32.dll
      0x77e70000 - 0x77f02000  C:\WINDOWS\system32\RPCRT4.dll
      0x77fe0000 - 0x77ff1000  C:\WINDOWS\system32\Secur32.dll
      0x77c10000 - 0x77c68000  C:\WINDOWS\system32\MSVCRT.dll
      0x76390000 - 0x763ad000  C:\WINDOWS\system32\IMM32.DLL
      0x72000000 - 0x72014000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.0.100.v20080509-1800\ecli pse_1114.dll
      0x77c00000 - 0x77c08000  C:\WINDOWS\system32\VERSION.dll
      0x6d7c0000 - 0x6da07000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\client\jvm.dll
      0x76b40000 - 0x76b6d000  C:\WINDOWS\system32\WINMM.dll
      0x7c340000 - 0x7c396000  C:\WINDOWS\system32\MSVCR71.dll
      0x6d310000 - 0x6d318000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\hpi.dll
      0x76bf0000 - 0x76bfb000  C:\WINDOWS\system32\PSAPI.DLL
      0x6d770000 - 0x6d77c000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\verify.dll
      0x6d3b0000 - 0x6d3cf000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\java.dll
      0x6d7b0000 - 0x6d7bf000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\zip.dll
      0x5ad70000 - 0x5ada8000  C:\WINDOWS\system32\uxtheme.dll
      0x74720000 - 0x7476c000  C:\WINDOWS\system32\MSCTF.dll
      0x003f0000 - 0x003fe000  C:\Program Files\Logitech\SetPoint\lgscroll.dll
      0x78130000 - 0x781cb000  C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\MS VCR80.dll
      0x77690000 - 0x776b1000  C:\WINDOWS\system32\NTMARTA.DLL
      0x774e0000 - 0x7761d000  C:\WINDOWS\system32\ole32.dll
      0x71bf0000 - 0x71c03000  C:\WINDOWS\system32\SAMLIB.dll
      0x76f60000 - 0x76f8c000  C:\WINDOWS\system32\WLDAP32.dll
      0x77b40000 - 0x77b62000  C:\WINDOWS\system32\apphelp.dll
      0x755c0000 - 0x755ee000  C:\WINDOWS\system32\msctfime.ime
      0x605d0000 - 0x605d9000  C:\WINDOWS\system32\mslbui.dll
      0x6d570000 - 0x6d583000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\net.dll
      0x71ab0000 - 0x71ac7000  C:\WINDOWS\system32\WS2_32.dll
      0x71aa0000 - 0x71aa8000  C:\WINDOWS\system32\WS2HELP.dll
      0x6d590000 - 0x6d599000  C:\Program Files\Adobe\Adobe Flash Catalyst\jre\bin\nio.dll
      0x77120000 - 0x771ab000  C:\WINDOWS\system32\OLEAUT32.DLL
      0x349f0000 - 0x34a45000  C:\Documents and Settings\xxxxxxxxx\Application Data\Adobe\Flash Catalyst\configuration\org.eclipse.osgi\bundles\198\1\.cp\swt-win32-3448.dll
      0x763b0000 - 0x763f9000  C:\WINDOWS\system32\comdlg32.dll
      0x773d0000 - 0x774d3000  C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.2600.5512_x- ww_35d4ce83\COMCTL32.dll
      0x77f60000 - 0x77fd6000  C:\WINDOWS\system32\SHLWAPI.dll
      0x7c9c0000 - 0x7d1d7000  C:\WINDOWS\system32\SHELL32.dll
      0x74d90000 - 0x74dfb000  C:\WINDOWS\system32\USP10.dll
      0x3d930000 - 0x3da16000  C:\WINDOWS\system32\WININET.dll
      0x34a50000 - 0x34a59000  C:\WINDOWS\system32\Normaliz.dll
      0x34a60000 - 0x34b92000  C:\WINDOWS\system32\urlmon.dll
      0x3dfd0000 - 0x3e1b8000  C:\WINDOWS\system32\iertutil.dll
      0x34f10000 - 0x34f50000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexbuilder.utils.osnative_1.0.0.235712\os\win32\x86\JNIToNati veBridge.dll
      0x36270000 - 0x36579000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\amtlib.dll
      0x5b860000 - 0x5b8b5000  C:\WINDOWS\system32\NETAPI32.dll
      0x4d4f0000 - 0x4d549000  C:\WINDOWS\system32\WINHTTP.dll
      0x36700000 - 0x36706000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\amt_win_jnilib.dll
      0x36720000 - 0x367bd000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\amtservices.dll
      0x368e0000 - 0x368f4000  C:\Documents and Settings\xxxxxxxxx\Application Data\Adobe\Flash Catalyst\configuration\org.eclipse.osgi\bundles\198\1\.cp\swt-gdip-win32-3448.dll
      0x4ec50000 - 0x4edf6000  C:\WINDOWS\WinSxS\x86_Microsoft.Windows.GdiPlus_6595b64144ccf1df_1.0.2600.5581_x-ww_dfbc4 fc4\gdiplus.dll
      0x36c60000 - 0x36c97000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\adobe_caps.dll
      0x7c420000 - 0x7c4a7000  C:\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3053_x-ww_b80fa8ca\MS VCP80.dll
      0x77920000 - 0x77a13000  C:\WINDOWS\system32\SETUPAPI.dll
      0x36da0000 - 0x36dc0000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\asneu.dll
      0x36fd0000 - 0x37253000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.amt_1.0.0.235712\os\win32\x86\AdobeLM_libFNP.dll
      0x76d60000 - 0x76d79000  C:\WINDOWS\system32\iphlpapi.dll
      0x71f60000 - 0x71f68000  C:\WINDOWS\system32\snmpapi.dll
      0x68000000 - 0x68036000  C:\WINDOWS\system32\rsaenh.dll
      0x37780000 - 0x37a45000  C:\WINDOWS\system32\xpsp2res.dll
      0x76fd0000 - 0x7704f000  C:\WINDOWS\system32\CLBCATQ.DLL
      0x77050000 - 0x77115000  C:\WINDOWS\system32\COMRes.dll
      0x71a50000 - 0x71a8f000  C:\WINDOWS\System32\mswsock.dll
      0x76f20000 - 0x76f47000  C:\WINDOWS\system32\DNSAPI.dll
      0x76fb0000 - 0x76fb8000  C:\WINDOWS\System32\winrnr.dll
      0x37290000 - 0x372b5000  C:\Program Files\Bonjour\mdnsNSP.dll
      0x76c30000 - 0x76c5e000  C:\WINDOWS\system32\WINTRUST.dll
      0x77a80000 - 0x77b15000  C:\WINDOWS\system32\CRYPT32.dll
      0x77b20000 - 0x77b32000  C:\WINDOWS\system32\MSASN1.dll
      0x76c90000 - 0x76cb8000  C:\WINDOWS\system32\IMAGEHLP.dll
      0x76fc0000 - 0x76fc6000  C:\WINDOWS\system32\rasadhlp.dll
      0x662b0000 - 0x66308000  C:\WINDOWS\system32\hnetcfg.dll
      0x71a90000 - 0x71a98000  C:\WINDOWS\System32\wshtcpip.dll
      0x76080000 - 0x760e5000  C:\WINDOWS\system32\MSVCP60.dll
      0x74290000 - 0x74294000  C:\WINDOWS\system32\icmp.Dll
      0x372e0000 - 0x372fb000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.embeddedplayer_1.0.0.235712\os\win32\x86\adbeape.dll
      0x37310000 - 0x37329000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.embeddedplayer_1.0.0.235712\os\win32\x86\EmbeddedPlaye rJNILib.dll
      0x384a0000 - 0x38ccb000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.embeddedplayer_1.0.0.235712\os\win32\x86\AdobeSWFL.dll
      0x76380000 - 0x76385000  C:\WINDOWS\system32\MSIMG32.dll
      0x73b30000 - 0x73b45000  C:\WINDOWS\system32\mscms.dll
      0x73000000 - 0x73026000  C:\WINDOWS\system32\WINSPOOL.DRV
      0x7d1e0000 - 0x7d49c000  C:\WINDOWS\system32\msi.dll
      0x75cf0000 - 0x75d81000  C:\WINDOWS\system32\mlang.dll
      0x72d20000 - 0x72d29000  C:\WINDOWS\system32\wdmaud.drv
      0x72d10000 - 0x72d18000  C:\WINDOWS\system32\msacm32.drv
      0x77be0000 - 0x77bf5000  C:\WINDOWS\system32\MSACM32.dll
      0x77bd0000 - 0x77bd7000  C:\WINDOWS\system32\midimap.dll
      0x66e90000 - 0x66ed1000  C:\WINDOWS\system32\icm32.dll
      0x767f0000 - 0x76818000  C:\WINDOWS\system32\schannel.dll
      0x769c0000 - 0x76a74000  C:\WINDOWS\system32\USERENV.dll
      0x40dd0000 - 0x40de0000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\os\win32\x86\NativeImporter.dl l
      0x40ef0000 - 0x40f3a000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\BIB.dll
      0x41060000 - 0x410a1000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\BIBUtils.dll
      0x410d0000 - 0x411c1000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\ACE.dll
      0x412f0000 - 0x418c3000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\AGM.dll
      0x418f0000 - 0x41942000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\ARE.dll
      0x41970000 - 0x41dcc000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\MPS.dll
      0x41df0000 - 0x4209e000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\CoolType.dll
      0x422c0000 - 0x423ca000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\PDFPort.dll
      0x423e0000 - 0x429a7000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\AdobePDFL.dll
      0x429c0000 - 0x42a2d000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\AdobeXMP.dll
      0x42a40000 - 0x42ae7000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\JP2KLib.dll
      0x71b20000 - 0x71b32000  C:\WINDOWS\system32\MPR.dll
      0x42b00000 - 0x42b2e000  C:\Program Files\Adobe\Adobe Flash Catalyst\plugins\com.adobe.flexide.nativelibs_1.0.0.235712\libs\AXE8SharedExpat.dll
      0x74c80000 - 0x74cac000  C:\WINDOWS\system32\oleacc.dll
      0x33e60000 - 0x33e68000  C:\Documents and Settings\xxxxxxxxx\Application Data\Adobe\Flash Catalyst\configuration\org.eclipse.osgi\bundles\85\1\.cp\os\win32\x86\localfile_1_0_0.dll
      0x33e80000 - 0x33e8f000  C:\Documents and Settings\xxxxxxxxx\Application Data\Adobe\Flash Catalyst\configuration\org.eclipse.osgi\bundles\90\1\.cp\jWinHttp.dll
      0x493e0000 - 0x493fa000  C:\WINDOWS\system32\hccutils.DLL
      0x49400000 - 0x4941a000  C:\Program Files\Dell\QuickSet\dadkeyb.dll
      0x7e290000 - 0x7e401000  C:\WINDOWS\system32\shdocvw.dll
      0x754d0000 - 0x75550000  C:\WINDOWS\system32\CRYPTUI.dll
      0x77a20000 - 0x77a74000  C:\WINDOWS\System32\cscui.dll
      0x76600000 - 0x7661d000  C:\WINDOWS\System32\CSCDLL.dll
      0x75f80000 - 0x7607d000  C:\WINDOWS\system32\browseui.dll
      0x76980000 - 0x76988000  C:\WINDOWS\system32\LINKINFO.dll
      0x76990000 - 0x769b5000  C:\WINDOWS\system32\ntshrui.dll
      0x76b20000 - 0x76b31000  C:\WINDOWS\system32\ATL.DLL
      0x75f60000 - 0x75f67000  C:\WINDOWS\System32\drprov.dll
      0x5fe60000 - 0x5fe6e000  C:\WINDOWS\System32\ntlanman.dll
      0x60150000 - 0x60167000  C:\WINDOWS\System32\NETUI0.dll
      0x607b0000 - 0x607f0000  C:\WINDOWS\System32\NETUI1.dll
      0x71c80000 - 0x71c87000  C:\WINDOWS\System32\NETRAP.dll
      0x75f70000 - 0x75f7a000  C:\WINDOWS\System32\davclnt.dll
      0x63a50000 - 0x63a99000  C:\WINDOWS\system32\PortableDeviceApi.dll
      VM Arguments:
      jvm_args: -Xms512m -Xmx512m -XX:MaxPermSize=256m -XX:PermSize=64m
      java_command: <unknown>
      Launcher Type: generic
      Environment Variables:
      CLASSPATH=.;C:\Program Files\Java\jre1.6.0_03\lib\ext\QTJava.zip
      PATH=C:/Program Files/Adobe/Adobe Flash Catalyst/jre/bin/client;C:/Program Files/Adobe/Adobe Flash Catalyst/jre/bin;C:\Program Files\Adobe\Adobe Flash Catalyst\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\AT&T Global Network Client\;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Intuit\QBPOSSDKRuntime;C:\Program Files\QuickTime\QTSystem\;C:\WINDOWS\system32\WindowsPowerShell\v1.0
      USERNAME=xxxxxxxxx
      OS=Windows_NT
      PROCESSOR_IDENTIFIER=x86 Family 6 Model 15 Stepping 11, GenuineIntel
      ---------------  S Y S T E M  ---------------
      OS: Windows XP Build 2600 Service Pack 3
      CPU:total 2 family 6, cmov, cx8, fxsr, mmx, sse, sse2
      Memory: 4k page, physical 2097151k(1555124k free), swap 4194303k(3495592k free)
      vm_info: Java HotSpot(TM) Client VM (1.6.0_01-b06) for windows-x86, built on Mar 14 2007 00:24:02 by "java_re" with unknown MS VC++:1310
      Message was edited by: Techfu. Adding error message text
        • 1. Re: Long startup and save times for Fc
          SupraJohde
          FC seems to save all the release versions inside the fxp file. I had one fxp project where i had made like 20 "export to swf". fxp file size was like 150MB and opening and saving time was about a minute. FC also started to bug a lot and did not save etc. So i switched to "CODE" mode and deleted all the previous release versions. File size dropped to 4MB and the saving was fast. That worked for me.
          • 2. Re: Long startup and save times for Fc
            Techfu Level 1
            I always wondered about all those bin-release## directories being formed had to do something with the slow down.
            Even thought Im not a code person, I opened the code view and deleted all the unwanted bin-release directories and looks like it did the trick. Now my fxp file size is down to like 30MB....and much much faster and stable.
            thank you very much for all the help,
            Fu
