Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Calculation Problem help solution needed quickly
Avatar
Level 2
I have created an adobe acrobat registration form in Adobe LiveCycle.  I've worked on this all day and needed to distribute today.  I can not find out what the problem with my code is.  I need a discerning eye right away if possible.  The calculated fields are on page two.  The right column TotTour, TotMDin, TotWDin & then TotDue
Nikki
1 Accepted Solution
Avatar
Correct answer by
Level 6
I.ve made some changes to youre scripts and saved form as dynamic. Now it calculates.
Hope this what you need.
BR,
Paul Butenko
View solution in original post
Avatar
Correct answer by
Level 6
BR,
Paul Butenko
Avatar
Level 2
I appreciate your help sooooooo much!.  My prayers were answered.  Kept studying my pdf bible but couldn't see the forest through the trees.
Nikki
Avatar
Level 2
Paul, The form was great in Preview, however when distributed it comes up with an error message and the form is all messes up and all amounts are $215.  Not sure how that happened.  I will continue working on it.
Nikki
Avatar
Level 6
1) Try to set default values for fields as 0 for example.
2) It could be prblem with versions of reader and form. Try to chane target version under File - Form properties - Preview
BR
Avatar
Level 2
Paul the problem was solved by someone else.  When I posted another post.  This is the answer I got, which worked.
Nothing wrong with your code.
Simply go to the Row1[0] and uncheck the "Repeat Row for Each Data Item" option
Nikki
